PINE A64-LTS/SOPine
SOPINE/PINE A64-LTS
SoPine OS images are compatible with PINE A64-LTS.
Under the 'SOPINE Software and OS Image Download Section' you can find a complete list of currently supported Operating System images that work with the SOPINE as well as other related software. The list includes OS images and descriptions of:
Available images include: Debian Jessie and Stretch as well as Ubuntu 16.04 and 17.10.
Quick Links to Build Sources of OS Images
Some these OS images labelled as beta or nightly builds which means they are only fit for testing purposes.
These images should be used at your own risk and are not fit for normal use.
Under 'Guides for PINE A64(+) accessories' you can find instructions and guides concerning:
  • Enclosures
  • Bluetooth and WiFi module
  • Real Time Clock (RTC) battery
  • Real Time Clock (RTC) battery holder
  • First and third party cases
  • Featured 3D printed cases (and more).
SoC and Memory Specification
  • Based on Allwinner A64
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • RAM Memory Variants: 2GB LPDDR3.
  • Storage Memory: SPI Flash and optional eMMC module from 16GB up to 64GB
Board Features
Video
  • HDMI 1.4a (Type A - full)
Audio
Network
  • 10/100/1000Mbps Ethernet(PINE A64+ version), 10/100Mbps Ethernet(PINE A64 version)
Storage
  • USB - 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • 2x17 pins "Euler" GPIO Header
  • 2x5 pins "EXP" Console Header
Pine A64 Board Information and Schematics
Pine A64 POT
Other Resources
