PINE A64-LTS
Revision as of 17:11, 21 April 2021 by Dsimic (talk | contribs) (→‎Accessories Step-by-Step Guides: More improvements)
Software and operating system images
Important: The SOPine operating system images are compatible with PINE A64-LTS.
Please see SOPINE Software Release for a complete list of currently supported operating system images that work with the SOPine, as well as other related software. For a quick reference, the list includes the following operating system images:
Below is a list of links to the build sources and environments for some operating system images. Some of themare labelled as beta or nightly builds, which means they are fit for testing purposes only. Those images should be used at your own risk and are not fit for regular use.
Accessories and Step-by-Step Guides
Please see Accessories Step by Step Guides for a list of guides for Pine A64 accessories; there you can find instructions and guides about the following:
  • Enclosures
  • Bluetooth and WiFi module
  • Real Time Clock (RTC) battery
  • Real Time Clock (RTC) battery holder
  • First and third party cases
  • Featured 3D printed cases (and more)
SoC and Memory Specification
  • Based on Allwinner A64/R18
    • R18 and A64 are identical SoC but R18 committed for 10 years supply by vendor.
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • RAM Memory Variants: 2GB LPDDR3.
  • Storage Memory: SPI Flash and optional eMMC module from 16GB up to 64GB
PINE A64-LTS Board Features
Front view of a Pine A64-LTS board
Rear view of a Pine A64-LTS board
Video
  • Digital Video (Type A - full)
Audio
Network
  • 10/100/1000Mbps Ethernet(PINE A64+ version), 10/100Mbps Ethernet(PINE A64 version)
Storage
  • USB - 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • 2x17 pins "Euler" GPIO Header
  • 2x5 pins "EXP" Console Header
Pine A64-LTS, SOPine Module and Baseboard Information, Schematics, and Certifications
Front view of a SOPine Baseboard
Front view of a SOPine module
Rear view of a SOPine module
Pine A64 POT
Other Resources
