PINE A64-LTS
Revision as of 09:05, 9 October 2020 by Abcde (talk | contribs) (added categories)
PINE A64-LTS / SOPINE
SOPine OS images are compatible with PINE A64-LTS
Under the 'SOPINE Software and OS Image Download Section' you can find a complete list of currently supported Operating System images that work with the SOPINE as well as other related software. The list includes OS images and descriptions of:
mate.png Xenial Mate           penguin.png Ayufan's Linux images for SOPine are available from his GitHub
android_7.png Android 7.x           android_6.png Android 6.x           android_5.png Android 5.x
opensuse.png openSUSE
armbian.png Armbian
archlinux.png Arch Linux mainline XFCE
nems.jpg NEMS Linux
omv.png OpenMediaVault
volumio.png Volumio Digital Audio Player
FreedomBox.jpg FreedomBox
openembedded.png OpenEmbedded/Yocto Images
Quick Links to Build Sources of OS Images
Some these OS images labelled as beta or nightly builds which means they are only fit for testing purposes
These images should be used at your own risk and are not fit for normal use
Under 'Guides for PINE A64(+) accessories' you can find instructions and guides concerning:
  • Enclosures
  • Bluetooth and WiFi module
  • Real Time Clock (RTC) battery
  • Real Time Clock (RTC) battery holder
  • First and third party cases
  • Featured 3D printed cases (and more)
SoC and Memory Specification
  • Based on Allwinner A64/R18
    • R18 and A64 are identical SoC but R18 committed for 10 years supply by vendor.
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • RAM Memory Variants: 2GB LPDDR3.
  • Storage Memory: SPI Flash and optional eMMC module from 16GB up to 64GB
PINE A64-LTS Board Features
Video
  • Digital Video (Type A - full)
Audio
Network
  • 10/100/1000Mbps Ethernet(PINE A64+ version), 10/100Mbps Ethernet(PINE A64 version)
Storage
  • USB - 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • 2x17 pins "Euler" GPIO Header
  • 2x5 pins "EXP" Console Header
Pine A64-LTS, SOPine Module and Baseboard Information, Schematics, and Certifications
Pine A64 POT
Pine64 Cluster Board Resource
Other Resources
