PINE A64-LTS
Revision as of 05:41, 31 October 2023 by Dsimic (talk | contribs) (→‎Serial console UART: Added new subsection)
The PINE A64-LTS
The PINE64-LTS is the long term supply version of the PINE A64 (+), PINE64's first single board computer, powered by Allwinner’s A64 quad-core ARM Cortex A53 64-Bit SoC. There are many operating systems available for the PINE A64-LTS created by the open source community and various partner projects. The PINE A64-LTS is guaranteed to be supplied until the year 2025 at the very least.
Software releases
The SOPINE operating system images are compatible with PINE A64-LTS. Under SOPINE Software Releases you will find a complete list of currently supported operating system images, which work with the PINE A64-LTS, as well as other related software.
Accessories and Step-by-Step Guides
Please see Accessories Step by Step Guides for a list of guides for Pine A64 accessories; there you can find instructions and guides about the following:
  • Enclosures
  • Bluetooth and WiFi module
  • Real Time Clock (RTC) battery
  • Real Time Clock (RTC) battery holder
  • First and third party cases
  • Featured 3D printed cases (and more)
SoC and Memory Specification
The PINE A64-LTS is based on the Allwinner A64/R18. The R18 and A64 are identical SoCs but the is R18 committed for a 10 years supply by the vendor.
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • RAM Memory Variants: 2GB LPDDR3.
  • Storage Memory: 128Mb SPI Flash and optional eMMC module from 16GB up to 128GB
PINE A64-LTS Board Features
Front view of a Pine A64-LTS board
Rear view of a Pine A64-LTS board
Video
  • Digital Video (Type A - full)
Audio
Network
  • 10/100/1000Mbps Ethernet(PINE A64+ version), 10/100Mbps Ethernet(PINE A64 version)
Storage
  • USB - 2 USB2.0 Host port
Expansion ports
  • DSI - Display Serial Interface, four-lane MiPi, up to 1080p
  • CSI - CMOS Camera Interface up to 5 megapixel
  • 2x20 pins "Pi2" GPIO Header
  • 2x17 pins "Euler" GPIO Header
  • 2x5 pins "EXP" Console Header
Serial console UART
An excerpt from the A64-LTS schematic, showing the EXP header
The "EXP" header, listed above, includes the TX, RX and GND pins for the serial console UART, also known as the debug UART, as visible in the picture in this section. The pin numbers are silkscreened on the top side of the A64-LTS PCB, making navigation easy.
This can be used to access the serial console of the boot loader, for example, which is often invaluable for debugging boot issues. To actually access the serial console, you can use these pins to connect, for example, a USB UART adapter that supports 3.3 V on the RX and TX lines, such as the "Woodpecker" USB UART adapter offered by the Pine Store.
Board Data and Schematic
Model "A" Baseboard dimensions: 133 mm x 80 mm x 19 mm
Power inputs:
  • DC barrel jack, 3.5 mm OD / 1.35 mm ID, 2 A at 5 V
  • 3.7 V lithium-ion battery connector
  • Euler connector
Schematics:
Pine A64-LTS schematic:
Pine A64-LTS V2 schematic:
Allwinner A64/R18 SoC information:
X-Powers AXP803 PMU (Power Management Unit) information:
LPDDR3 information:
eMMC information:
SPI NOR Flash information:
Related to the PINE A64-LTS:
Pine A64 POT
Other Resources
