PINE A64-LTS
Revision as of 22:28, 30 October 2023 by Dsimic (talk | contribs) (→‎Schematics and certifications: Make it visible)
The PINE A64-LTS
The PINE64-LTS is the long term supply version of the PINE A64 (+), PINE64's first single board computer, powered by Allwinner’s A64 quad-core ARM Cortex A53 64-Bit SoC. There are many operating systems available for the PINE A64-LTS created by the open source community and various partner projects. The PINE A64-LTS is guaranteed to be supplied until the year 2025 at the very least.
Software releases
The SOPINE operating system images are compatible with PINE A64-LTS. Under SOPINE Software Releases you will find a complete list of currently supported operating system images, which work with the PINE A64-LTS, as well as other related software.
Accessories and Step-by-Step Guides
Please see Accessories Step by Step Guides for a list of guides for Pine A64 accessories; there you can find instructions and guides about the following:
  • Enclosures
  • Bluetooth and WiFi module
  • Real Time Clock (RTC) battery
  • Real Time Clock (RTC) battery holder
  • First and third party cases
  • Featured 3D printed cases (and more)
SoC and Memory Specification
The PINE A64-LTS is based on the Allwinner A64/R18. The R18 and A64 are identical SoCs but the is R18 committed for a 10 years supply by the vendor.
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • RAM Memory Variants: 2GB LPDDR3.
  • Storage Memory: 128Mb SPI Flash and optional eMMC module from 16GB up to 128GB
PINE A64-LTS Board Features
Front view of a Pine A64-LTS board
Rear view of a Pine A64-LTS board
Video
  • Digital Video (Type A - full)
Audio
Network
  • 10/100/1000Mbps Ethernet(PINE A64+ version), 10/100Mbps Ethernet(PINE A64 version)
Storage
  • USB - 2 USB2.0 Host port
Expansion ports
  • 2x20 pins "Pi2" GPIO Header
  • 2x17 pins "Euler" GPIO Header
  • 2x5 pins "EXP" Console Header
Model "A" Baseboard dimensions: 133 mm x 80 mm x 19 mm
Power inputs:
  • DC barrel jack, 3.5 mm OD / 1.35 mm ID, 2 A at 5 V
  • 3.7 V lithium-ion battery connector
  • Euler connector
Schematics:
Pine A64-LTS schematic:
Pine A64-LTS V2 schematic:
Allwinner A64/R18 SoC information:
X-Powers AXP803 PMU (Power Management Unit) information:
LPDDR3 information:
eMMC information:
SPI NOR Flash information:
Related to the PINE A64-LTS:
Pine A64 POT
Other Resources
