PINE A64-LTS
Revision as of 00:27, 17 October 2017 by Tllim (talk | contribs)
SOPINE/PINE A64-LTS
Note that, SOPINE OS images are also compatible with PINE A64-LTS.
Under the 'SOPINE Software and OS Image Download Section' you can find a complete list of currently supported Operating System images that work with the SOPINE as well as other related software. The list includes OS images and descriptions of:
Some OS images are still in beta or nightly build which are only fit for testing purposes. These should usually be avoided for normal usage, since they are used at your own risk.
Under 'Guides for PINE A64(+) accessories' you can find instructions and guides pertaining to:
  • Enclosures
  • Bluetooth and WiFi module
  • Real Time Clock (RTC) battery
  • Real Time Clock (RTC) battery holder
  • First and third party cases
  • Featured 3D printed cases (and more).
SoC and Memory Specification
  • Based on Allwinner A64
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • RAM Memory Variants: 512MB, 1GB and 2GB.
  • Storage Memory: PINE A64 boards do not have built-in Flash memory but use bootable microSD Cards or USB attached storage.
Board Features
Video
  • HDMI 1.4a (Type A - full)
Audio
Network
  • 10/100/1000Mbps Ethernet(PINE A64+ version), 10/100Mbps Ethernet(PINE A64 version)
Storage
  • USB - 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • 2x17 pins "Euler" GPIO Header
  • 2x5 pins "EXP" Console Header
Pine A64 Board Information and Schematics
Pine A64 POT
Other Resources
