PINE A64
Revision as of 22:09, 28 October 2020 by Fxc (talk | contribs) (https)
PINE A64(+)
Note that PINE A64(+) OS images are not compatible with PINE A64-LTS due to its LPDDR3 memory configuration.
For PINE A64-LTS OS image downloads please refer to the SoPine and Pine64-LTS Section
Under PINE A64(+) Software and OS Image Download Section you will find a complete list of currently supported Operating System images that work with the PINE A64(+) as well as other related software.
Arch mainline Linux XFCE
Armbian
Cent OS
DietPi
LibreELEC(KODI)
FreedomBox
AOSC
NEMS Linux
openHAB 2
motionEyeOS
NetBSD
Android 7.x / Android 6.x / Android 5.x
Xenial Mate / Xenial Base Image / Xenial Minimal Image
Bliss OS
Debian Jessie Mate
Fedora Base Image
Gentoo
Q4OS
OpenWRT
China NeoKylin “中标麒麟”
RetroArch-APK-Download.png Retroarch
Volumio Digital Audio Player
FalconGate
OpenMediaVault
Windows 10 IoT [DISCONTINUED]
Remix OS [DISCONTINUED]
Under 'Guides for PINE A64(+) accessories' you can find instructions and guides pertaining to:
  • Enclosures
  • Bluetooth and WiFi module
  • Real Time Clock (RTC) battery
  • Real Time Clock (RTC) battery holder
  • First and third party cases
  • Featured 3D printed cases (and more).
SoC and Memory Specification
  • Based on Allwinner A64
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • RAM Memory Variants: 512MB, 1GB and 2GB DDR3.
  • Storage Memory: PINE A64 boards do not have built-in Flash memory but use bootable microSD Cards or USB attached storage.
Board Features
Video
  • Digital Video Port (Type A - full)
Audio
Network
  • 10/100/1000Mbps Ethernet(PINE A64+ version), 10/100Mbps Ethernet(PINE A64 version)
Storage
  • USB - 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • 2x17 pins "Euler" GPIO Header
  • 2x5 pins "EXP" Console Header
Pine A64 Board Information, Schematics and Certifications
Pine A64 POT
Other Resources
