PINE A64
Revision as of 14:24, 17 January 2020 by Pander (Talk | contribs)
Jump to: navigation, search
PINE A64(+)
Note that PINE A64(+) OS images are not compatible with PINE A64-LTS due to its LPDDR3 memory configuration.
For PINE A64-LTS OS image downloads please refer to the SoPine and Pine64-LTS Section
Under PINE A64(+) Software and OS Image Download Section you will find a complete list of currently supported Operating System images that work with the PINE A64(+) as well as other related software.
archlinux.png Arch mainline Linux XFCE
armbian.png Armbian
centos.jpg Cent OS
dietpi.png DietPi
libreelec.png LibreELEC(KODI)
FreedomBox.jpg FreedomBox
aosc.png AOSC
nems.jpg NEMS Linux
openhab.png openHAB 2
motioneyeos.png motionEyeOS
netbsd.png NetBSD
android_7.png Android 7.x           android_6.png Android 6.x           android_5.png Android 5.x
mate.png Xenial Mate           penguin.png Xenial Base Image           penguin.png Xenial Minimal Image
bliss_os.png Bliss OS
opensuse.png openSUSE
debian.png Debian Jessie Mate
fedora.png Fedora Base Image
gentoo.png Gentoo
q4os.png Q4OS
OpenWrt.png OpenWRT
neokylin.png China NeoKylin “中标麒麟”
RetroArch-APK-Download.png Retroarch
volumio.png Volumio Digital Audio Player
falcongate.png FalconGate
omv.png OpenMediaVault
win10iot.png Windows 10 IoT [DISCONTINUED]
remix_os.png Remix OS [DISCONTINUED]
Under 'Guides for PINE A64(+) accessories' you can find instructions and guides pertaining to:
  • Enclosures
  • Bluetooth and WiFi module
  • Real Time Clock (RTC) battery
  • Real Time Clock (RTC) battery holder
  • First and third party cases
  • Featured 3D printed cases (and more).
SoC and Memory Specification
  • Based on Allwinner A64
  • Quad-core ARM Cortex-A53 [email protected]
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • RAM Memory Variants: 512MB, 1GB and 2GB DDR3.
  • Storage Memory: PINE A64 boards do not have built-in Flash memory but use bootable microSD Cards or USB attached storage.
Board Features
Video
  • Digital Video Port (Type A - full)
Audio
Network
  • 10/100/1000Mbps Ethernet(PINE A64+ version), 10/100Mbps Ethernet(PINE A64 version)
Storage
  • USB - 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • 2x17 pins "Euler" GPIO Header
  • 2x5 pins "EXP" Console Header
Pine A64 Board Information, Schematics and Certifications
Pine A64 POT
Other Resources
