PINE A64
Revision as of 08:43, 27 August 2023 by Fxc (talk | contribs) (→‎Software releases: Specified the section, removed old mentions)
The PINE A64
The PINE A64 and the PINE A64+ is PINE64's first Single Board Computer powered by Allwinner’s A64 quad-core ARM Cortex A53 64-Bit SoC. There are many Operating Systems available for the PINE A64 created by the open source community and various partner projects. Currently the majority of Linux distributions for the PINE A64 are using mainline Linux but there are a number of BSP-based distribution and / or legacy systems that can be downloaded too.
Software releases
Under PINE A64 Software Releases you will find a complete list of currently supported operating system images, which work with the PINE A64 and PINE A64+, as well as other related software.
Under Accessories Step by Step Guides you can find instructions and guides pertaining to:
  • Enclosures
  • Bluetooth and WiFi module
  • Real Time Clock (RTC) battery
  • Real Time Clock (RTC) battery holder
  • First and third party cases
  • Featured 3D printed cases (and more).
SoC and Memory Specification
  • Based on Allwinner A64
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • RAM Memory Variants: 512MB, 1GB and 2GB DDR3.
  • Storage Memory: PINE A64 boards do not have built-in Flash memory but use bootable microSD Cards or USB attached storage.
Board Features
Video
  • Digital Video Port (Type A - full)
Audio
Network
  • 10/100/1000Mbps Ethernet (PINE A64+ version), 10/100Mbps Ethernet (PINE A64 version)
Storage
  • USB - 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • 2x17 pins "Euler" GPIO Header
  • 2x5 pins "EXP" Console Header
Information, Schematics and Certifications
Board Dimensions: 133mm x 80mm x 19mm
Input Power: DC 5V @ 2A, 3.7V Li-Ion battery connector, microUSB connector, Euler connector
Schematics and general files:
Board schematics:
Stereo audio DAC schematics:
Certifications:
  • Disclaimer: Please note that PINE64 SBC is not a "final" product and in general certification is not necessary. However, PINE64 still submit the SBC for FCC, CE, and ROHS certifications and obtain the certificates to prove that the SBC board can pass the testing. Please note, a final commercial product needs to perform its own testing and obtain its own certificate.
  • PINE A64 FCC Certificate
  • PINE A64 CE Certificate
  • PINE A64 RoHS Certificate
Allwinner A64 SoC information:
X-Powers AXP803 PMU (Power Management Unit) information:
PINE A64, PINE A64+ and SOPINE Related:
Pine A64 POT
Other Resources
