Oz64
The Oz64 SBC
The Oz64 3D model
The Oz64 is a low cost single-board computer based on the Sophgo SG2000 SoC with dual T-Head C906 64-bit RISC-V cores, an ARM Cortex A53 64-bit RISC CPU core and an 8051 8-bit core supported by 512 MB of embedded DRAM memory, with WiFi and Bluetooh radio interfaces. The Oz64 SBC comes in a model-B form-factor, has a microSD card slot, an eMMC plugin connector, an USB 2.0 Type-A host port, and many other peripheral interfaces for makers to integrate with sensors and other devices.
Software Releases
There is a community effort to bring updated kernels, peripherals and buildroot - Lots of communication happening in the #ox64-nutcracker channel.
Toolchain:
  • elf_newlib_toolchain/bin/riscv64-unknown-elf-gcc (Xuantie-900 elf newlib gcc Toolchain V2.2.5 B-20220323) 10.2.0
  • linux_toolchain/bin/riscv64-unknown-linux-gnu-gcc (Xuantie-900 linux-5.10.4 glibc gcc Toolchain V2.2.4 B-20211227) 10.2.0
  • cmake version 3.19.3
Software Development Kits
SoC and Memory Specification
Based on the Sophgo SG-200x
T-Head C906 1GHz MHz 64-bit RISC-V CPU:
  • Supports RISC-V RV64IMAFCV instruction architecture
  • Five-stage single-issue sequentially executed pipeline
  • Level-1 instruction and data cache of Harvard architecture, with a size of 32 KB and a cache line of 64KB
  • Level-2 128KB cache
  • Sv39 memory management unit, realizing the conversion of virtual and real addresses and memory management
  • jTLB that supports 128 entries
  • Supports AXI 4.0 128-bit master interface
  • Supports core local interrupt (CLINT) and platform-level interrupt controller (PLIC)
  • With 80 external interrupt sources, 3 bits for configuring interrupt priority
  • Supports BHT (8K) and BTB
  • Compatible with RISC-V PMP, 8 configurable areas
  • Supports hardware performance monitor (HPM) units
  • See here
T-Head C906 700Mhz MHz 64-bit RISC-V CPU:
  • Level-1 instruction and data cache of Harvard architecture, with a size of 16 KB and a cache line of 16KB
  • See here
ARM Cortex-A53 1GHz 64-bit RISC CPU:
  • Quad-core Cortex-A53 up to 1.0GHz CPU
  • Unified system L2 128KB cache
  • Includes VFP v3 hardware to support single and double-precision operations
  • Integrated 32KB L1 instruction cache, 32KB 4-way set associative L1 data cache
8051 25-300MHz 8-bit CPU:
  • Integrated 8K SRAM
  • SIP DRAM 512MB
Board Features
Network
  • 2.4 GHz 1T1R WiFi6
  • Bluetooth 5.2
  • 10/100 Mbit/s Ethernet with optional PoE capability
Storage
  • On-board eMMC module socket
  • MicroSD, supports SDHC and SDXC
Expansion Ports
  • USB 2.0 Host port
  • 26 GPIO pins, including SPI, I2C and UART functionality
  • 2x Dual-lane MiPi CSI port
  • Optional dual-lane MiPi DSI port
Board Dimensions: 85mm x 56mm x 18.8mm, see the model-B board dimension drawing
Input Power: +5V @2A with 3.5mm/1.35mm Type H Barrel type DC connector (@1.5A will work if there is no heavy load on the USB 2.0 port)
Pre-Production version schematic:
Board Pinout Diagram:
Certifications:
  • Disclaimer: Please note that PINE64 SBC is not a "final" product and in general certification is not necessary.
Sophgo SG2000 SoC information:
Wifi/BT information:
Power Regulator information:
MicroSD socket information:
Resources and Articles
Development Efforts
Build
