Ox64
Revision as of 13:39, 8 October 2023 by Pavlos1 (talk | contribs) (Added instructions for open-source flashing)
The Ox64
Pinout of the production version
Powered by RISC-V
The Ox64 is a RISC-V based Single Board Computer powered by Bouffalo Lab BL808 C906 64-Bit RISC-V CPU, 32-Bit CPU, embedded 64MB PSRAM memory and build-on 3 radio RF (Wifi, BT, Zigbee). It provides breadboard friendly form factor, MicroSD Card slot, USB 2.0, and many other peripheral interfaces for makers to integrate with sensors and other devices.
Software Releases
There is a community effort to bring updated kernels, peripherals and buildroot - Lots of communication happening in the #ox64-nutcracker channel.
  • buildroot bringing all the work below together with a bootable kernel and updated filesystem images for SD cards
  • U-Boot and OpenSBI work by Smauel
  • Kernel IRQChip, SDCard, and (WIP) USB by arm000, Alexander Horner and others
  • OpenBouffalo Firmware low_load drivers by Fishwaldo and others
Original Linux Images provided by Bouffalo - Very basic alpha build which are only fit for board bring up and testing purposes.
Toolchain:
  • elf_newlib_toolchain/bin/riscv64-unknown-elf-gcc (Xuantie-900 elf newlib gcc Toolchain V2.2.5 B-20220323) 10.2.0
  • linux_toolchain/bin/riscv64-unknown-linux-gnu-gcc (Xuantie-900 linux-5.10.4 glibc gcc Toolchain V2.2.4 B-20211227) 10.2.0
  • cmake version 3.19.3
Software Development Kits
SoC and Memory Specification
Based on the Bouffalo Lab BL808
T-Head C906 480MHz 64-bit RISC-V CPU:
  • Supports RISC-V RV64IMAFCV instruction architecture
  • Five-stage single-issue sequentially executed pipeline
  • Level-1 instruction and data cache of Harvard architecture, with a size of 32 KB and a cache line of 64B
  • Sv39 memory management unit, realizing the conversion of virtual and real addresses and memory management
  • jTLB that supports 128 entries
  • Supports AXI 4.0 128-bit master interface
  • Supports core local interrupt (CLINT) and platform-level interrupt controller (PLIC)
  • With 80 external interrupt sources, 3 bits for configuring interrupt priority
  • Supports BHT (8K) and BTB
  • Compatible with RISC-V PMP, 8 configurable areas
  • Supports hardware performance monitor (HPM) units
  • See here
T-Head E907 320MHz 32-bit RISC-V CPU:
  • Supports RISC-V RV32IMAFCP instruction set
  • Supports RISC-V 32-bit/16-bit mixed instruction set
  • Supports RISC-V machine mode and user mode
  • Thirty-two 32-bit integer general purpose registers (GPR) and thirty-two 32-bit/64-bit floating-point GPRs
  • Integer (5-stage)/floating-point (7-stage), single-issue, sequentially executed pipeline
  • Supports AXI 4.0 main device interface and AHB 5.0 peripheral interface
  • 32K instruction cache, two-way set associative structure
  • 16K data cache, two-way set associative structure
  • See here
T-Head E902 150MHz 32-bit RISC-V CPU:
  • Embedded 64MB PSRAM
Board Features
Network
  • 2.4GHz 1T1R WiFi 802.11 b/g/n
  • Bluetooth 5.2
  • Zigbee
  • 10/100Mbps Ethernet (optional, on expansion board)
Storage
  • On-board 16Mb (2MB) or 128Mb (16MB) XSPI NOR flash memory
  • MicroSD - supports SDHC and SDXC (only 128Mb version)
Expansion Ports
  • USB 2.0 OTG port
  • 26 GPIO Pins, including SPI, I2C and UART functionality. Possible I2S and GMII expansion
  • Dual lane MiPi CSI port, located at USB-C port, for camera module
Audio
  • Microphone (optional, on camera module)
  • Speaker (optional, on camera module)
Pinout for wiring ethernet PHY to EMAC
  • Baseboard Dimensions: 51mm x 21mm x 19mm x 3.5mm (Breadboard friendly)
  • Input Power: 5V 0.5A microUSB or USB-C port
Production version schematic:
Prototype (dispatched to developers) schematic:
Certifications:
  • Disclaimer: Please note that PINE64 SBC is not a "final" product and in general certification is not necessary.
  • Not yet available
Bouffalo BL808 SoC information:
SPI NOR Flash information:
Power Regulator information:
MicroSD socket information:
Compatible UARTs when in bootloader mode
When the Ox64 is in bootloader mode, some UARTs are unable to communicate with it. When this is the case, utilities such as BLDevCube are unable to actually program the device. If you see "Shake hand fail" and an empty ack, and your device is in bootloader mode, then it is likely an incompatible UART.
The below devices have been tested and verified as working:
  • Raspberry Pi Pico - running the following UART firmware (GP4 and GP5 are used for port 0, GP12 and GP13 for port 1)
  • Compiled binary for Pi Pico and connectivity diagram is here
  • ESP32 with CP210x - bridge the EN pin to ground to disable the ESP32 itself, and then connect the TX on the esp32 to 14 on the Ox64 and RX to pin 15. Note that only baud rate 115200 works, and this doesn't seem to work for everyone)
  • Stand-alone CP2102 dongle works at 115200 baud. Brand used was HiLetgo.
  • STM32F401 BlackPill - running the Black Magic Debug firmware
  • STM32F103C8T6 BluePill - running Black Magic Debug.
  • Some UART adapters based on the FT232H (note that the FT232RL does not work, and neither does the Pine 64 JTAG)
  • Some CH340G based adapters work and some don't.
Resources
Git repositories:
Development Efforts
Build
Open the terminal and create a new directory for the build:
mkdir buildroot_bouffalo && cd buildroot_bouffalo
Clone the primary Buildroot repository and the specific Buildroot Bouffalo repository:
git clone https://github.com/buildroot/buildroot
git clone https://github.com/openbouffalo/buildroot_bouffalo
Define an environment variable for the Buildroot Bouffalo overlay path:
export BR_BOUFFALO_OVERLAY_PATH=$(pwd)/buildroot_bouffalo
Change directory into the cloned Buildroot folder:
cd buildroot
Apply the default configuration for Pine64 Ox64:
make BR2_EXTERNAL=$BR_BOUFFALO_OVERLAY_PATH pine64_ox64_defconfig
Use the menuconfig tool to adjust build settings:
make menuconfig
Note: Within menuconfig:
  • Navigate to Target Architecture.
  • Enable Single-precision Floating-point and Double-precision Floating-point.
  • Set Target ABI to lp64d.
target ABI setting
  • Under Toolchain, enable Fortran support and OpenMP support.
toolchain setting
Initiate the build process:
make
Note: Before executing the make command, ensure your PATH variable doesn't have spaces.
Flashing Ox64 SBC and SD Card for Newbies
This section explains how to flash Ox64 board and the SD card to boot the system. It's very low level for newbies.
Wiring Raspberry Pico Pi to Pine64 Ox64 SBC
Prepare the Environment
You need a Linux machine, a Uart module (i.e Raspberry Pico Pi), the Ox64 board and a SD card.
Start a terminal session and set the working directory
cd ~/Downloads
mkdir ox64 ox64/devcube183
cd ~/Downloads/ox64/devcube183
Get flasher DevCube 1.8.3 from one of mirrored servers and decompress it:
SHA1: 0f2619e87d946f936f63ae97b0efd674357b1166
SHA256SUMS: e6e6db316359da40d29971a1889d41c9e97d5b1ff1a8636e9e6960b6ff960913
wget https://openbouffalo.org/static-assets/bldevcube/BouffaloLabDevCube-v1.8.3.zip
unzip BouffaloLabDevCube-v1.8.3.zip
chmod u+x BLDevCube-ubuntu
Download compressed file from https://github.com/openbouffalo/buildroot_bouffalo/releases/ and decompress it.
(You can also get the compressed the file from https://github.com/openbouffalo/buildroot_bouffalo/releases/download/v1.0.1/bl808-linux-pine64_ox64_full_defconfig.tar.gz)
cd ~/Downloads/ox64
mkdir openbouffalo && cd openbouffalo
wget https://github.com/openbouffalo/buildroot_bouffalo/releases/download/v1.0.1/bl808-linux-pine64_ox64_full_defconfig.tar.gz
tar -xvzf bl808-linux-pine64_ox64_full_defconfig.tar.gz
You'll get this structure
  |_ firmware/
  |_ firmware/m0_lowload_bl808_m0.bin
  |_ firmware/bl808-firmware.bin
  |_ firmware/d0_lowload_bl808_d0.bin
  |_ firmware/sdcard-pine64_ox64_full_defconfig.img.xz
Flash Ox64
Connect the the Uart module (i.e Raspberry Pico Pi) for serial communicate from PC to Ox64
ls /dev/ttyACM*
There are two new ports to choose from : /dev/ttyACM0 /dev/ttyACM1, use the lower number.
minicom -b 2000000 -D /dev/ttyACM0
Set ox64 board to programming mode
  • Press BOOT button
  • Apply power
  • Release BOOT button
Close minicom. Open a new terminal window to run DevCube flasher
./BLDevCube-ubuntu
Select chip [BL808], press Finish and switch to [MCU] tab
M0 Group[group0] Image Addr [0x58000000] [PATH to m0_lowload_bl808_m0.bin]
D0 Group[group0] Image Addr [0x58100000] [PATH to d0_lowload_bl808_d0.bin]
Interface: Uart
Port/SN: /dev/ttyACM1
Uart rate 2000000
UART TX is physical pin 1/GPIO 14.
UART RX is physical pin 2/GPIO 15.
Click 'Create & Download' and wait until it's done
Switch to [IOT] tab
Enable 'Single Download', set Address with 0x800000, choose [PATH to bl808-firmware.bin]
Click 'Create & Download' again and wait until it's done
Close DevCube
Alternative: Open-Source Flashing
For those who do not want to use the DevCube, BouffaloLab provide open-source flashing packages — bflb-iot-tool and bflb-mcu-tool.
Note: While these packages do contain binaries in addition to the Python source code, those binaries do not appear to be used for UART flashing.
Execute the following commands to flash the BL808. Note that the addresses are different to the ones you would use in the DevCube.
Reminder: UART TX is physical pin 1/GPIO 14, UART RX is physical pin 2/GPIO 15.
pip install bflb-iot-tool # we are *not* using bflb-mcu-tool
bflb-iot-tool --chipname bl808 --interface uart --port /dev/ttyACM0 --addr 0x000000 --firmware firmware/m0_lowload_bl808_m0.bin --single
bflb-iot-tool --chipname bl808 --interface uart --port /dev/ttyACM0 --addr 0x100000 --firmware firmware/d0_lowload_bl808_d0.bin --single
bflb-iot-tool --chipname bl808 --interface uart --port /dev/ttyACM0 --addr 0x800000 --firmware firmware/bl808-firmware.bin --single
Flash SD Card
Insert SD card into PC, find address [/dev/sdb], erase initial space and flash sdcard.xxxx.img file.
cd ~/Downloads/ox64/openbouffalo/firmware
xz -v -d -k sdcard-pine64_ox64_full_defconfig.img.xz
sudo dd if=/dev/zero of=/dev/sdb count=1 bs=32768
sudo dd if=~/Downloads/ox64/openbouffalo/firmware/sdcard-pine64_ox64_full_defconfig.img of=/dev/sdb bs=1M status=progress conv=fsync
First Booting
Insert SD card into Ox64 and set a tty connection to Ox64 board
  • Serial Console access:
  • UART TX is physical pin 32/GPIO 16.
  • UART RX is physical pin 31/GPIO 17.
  • Baud 2000000.
Re-Apply power to ox64
Enjoy the boot!
PS. To investigate running services
pstree | head -5
  init-+-dhcpcd---3*[dhcpcd]
       |-dropbear
       |-klogd
       |-login---sh-+-head
       |            `-pstree
