Overclocking
This might damage your equipment or may result in a unstable system, so do this at your own risk!
This page is incomplete, you're welcome to improve it.
Overclocked devices may seem stable but crash occasionally and be hard to debug. A good test suite needs to be found to properly test the entire functionality of overclocked devices to properly ensure stability
All information regarding clock speeds, voltages and more are stored in the DTB (Device Tree Blob). You can learn more about it here.
Overclocking is a way to get more and better performance out of the system by running it at higher clock speeds than the factory default.
Preparation
TODO, requires a compatible cross compiler (usually aarch64-linux-gnu), and clone the pine64 kernel repository.
Then after that just setup the variables for make.
A64-based boards
GPU
Open arch/arm64/boot/dts/allwinner/sun50i-a64.dtsi in a text editor.
Look for
		mali: gpu@1c40000 {
			compatible = "allwinner,sun50i-a64-mali", "arm,mali-400";
			reg = <0x01c40000 0x10000>;
			interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>,
				     <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>;
			interrupt-names = "gp",
					  "gpmmu",
					  "pp0",
					  "ppmmu0",
					  "pp1",
					  "ppmmu1",
					  "pmu";
			clocks = <&ccu CLK_BUS_GPU>, <&ccu CLK_GPU>;
			clock-names = "bus", "core";
			resets = <&ccu RST_BUS_GPU>;
			assigned-clocks = <&ccu CLK_GPU>;
			assigned-clock-rates = <432000000>;
The assigned-clock-rates line is set to 432000000, this means that the GPU is clocked at 432MHz. So if you want 500MHz, set the value to 500000000.
Save the dtsi file, and recompile the DTB.
Danct12 has found on his Pinetab that 562 MHz is the limit for stable operation.
Remember to run a benchmark tool (such as glmark2-es2) to make sure that it's stable! If it's not, then lower the clock speed until you can get a stable clock speed.
CPU
TODO
DRAM
It is not recommended to exceed 672 MHz clockspeed on the DRAM.
When overclocking the GPU, it is a good idea to also overclock the DRAM, as the main bottleneck of the A64 SOC is the memory.
Rockchip
TODO
TuxThePenguin has found that the RK3399 in his Pinebook Pro can reach 950MHz on the GPU while being stable, 1GHz was tried but crashed instantly.
