User:Pineadmin/OpenMediaVault
Revision as of 07:01, 24 January 2018 by Pineadmin (talk | contribs)
Please go through the OpenMediaVault Basic Setup and all following chapters about OpenMediaVault before proceed to the more advance setup below.
Dynamic DNS
[YOU CAN SKIP THIS IF YOU ARE USING STATIC IP ON YOUR INTERNET WAN OR YOU ALREADY KNOW HOW TO SETUP DYNAMIC DNS ON YOUR INTERNET MODEM/ROUTER]
1. SSH to the device
2. # apt-get install ddclient  (no-ip.com example)
Dynamic DNS service provider: other
Dynamic DNS server: dynupdate.no-ip.com
Dynamic DNS update protocol: dyndns2
Username for dynamic DNS service: <<<USERNAME/EMAIL>>>
Password for dynamic DNS service: <<<PASSWORD>>>
Re-enter password to verify: <<<PASSWORD>>>
Network interface used for dynamic DNS service: web
DynDNS fully qualified domain names: <<<CNAME>>>.ddns.net
Run ddclient on PPP connect? No
Run ddclient as daemon? Yes
Interval between ddclient runs: 300
# dpkg-reconfigure ddclient  (To Re-run configuration wizard above)
3. # vi /etc/ddclient.conf
Change: use=if, if=web
To:     use=web, web=checkip.dyndns.com, web-skip='Current IP Address'
protocol=dyndns2
server=dynupdate.no-ip.com
login=<<<USERNAME/EMAIL>>>
password='<<<PASSWORD>>>'
4. # systemctl restart ddclient  (Restart ddclient after changed in configuration)
5. Diagnostics:
# ddclient -daemon=0 -debug -verbose -noquiet
# systemctl status ddclient
NextCloud
Reference: https://forum.openmediavault.org/index.php/Thread/17738-NextCloud-Installation/
# apt-get update
# apt-get upgrade
   - Configuring openmediavault -> Press [Tab] -> Press [Enter] on Ok
# apt-get install php5-curl php5-gd
2. Create the Shared Folders for all your Nginx's web pages
    - Name: www
    - Path: www/
    - Click on the ACL
      - User/Groups permissions: Tick Read/Write for both www-data user and group
      - Set Owner / Group to Read/Write/Execute and Others to None
3. Create the sub shared folder for your NextCloud web pages
    - Name: nextcloud
    - Path: www/nextcloud
    - Click on the ACL
4. Go to System -> Plugins -> Tick openmediavault-nginx -> Install
5. Services -> Nginx -> Settings -> Enable -> Save -> Apply
6. Services -> Nginx -> Pools -> Add
    - Name: pool_nextcloud
    - User: www-data
    - Group: www-data
    - Extra options: <<<Copy Texts In Between ########## Below>>>
clear_env = no
env[HOSTNAME] = $HOSTNAME
env[PATH] = /usr/local/bin:/usr/bin:/bin
env[TMP] = /tmp
env[TMPDIR] = /tmp
env[TEMP] = /tmp
    - Save -> Apply
7. Services -> Nginx -> Servers -> Add
    - General
       - Directory: nextcloud
    - SSL
       - Enable SSL: Enable
       - Port: 91
       - Certificate: <<<Select Created SSL Certificate>>>
          - System -> Certificates -> SSL -> Add -> Create (Set longer "Period of validity" if you do not want to renew the certificate too frequently) -> Save -> Apply
       - Only use SSL: Enable
    - PHP
       - Enable PHP: Enable
       - PHP-FPM Pool: pool_nextcloud
add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;";
add_header X-Content-Type-Options nosniff;
add_header X-Frame-Options "SAMEORIGIN";
add_header X-XSS-Protection "1; mode=block";
add_header X-Robots-Tag none;
add_header X-Download-Options noopen;
add_header X-Permitted-Cross-Domain-Policies none;
location = /robots.txt {
log_not_found off;
allow all;
access_log off;
# The following 2 rules are only needed for the user_webfinger app.
# Uncomment it if you're planning to use this app.
#rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
#rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json
# last;
location = /.well-known/carddav {
return 301 $scheme://$host/remote.php/dav;
location = /.well-known/caldav {
# set max upload size
client_max_body_size 50G;
fastcgi_buffers 64 4K;
# Disable gzip to avoid the removal of the ETag header
gzip off;
# Uncomment if your server is build with the ngx_pagespeed module
# This module is currently not supported.
#pagespeed off;
error_page 403 /core/templates/403.php;
error_page 404 /core/templates/404.php;
location / {
rewrite ^ /index.php$uri;
location ~ ^/(?:build|tests|config|lib|3rdparty|templates|data)/ {
deny all;
location ~ ^/(?:\.|autotest|occ|issue|indie|db_|console) {
deny all;
location ~ ^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+|core/templates/40[34])\.php(?:$|/) {
fastcgi_split_path_info ^(.+\.php)(/.*)$;
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
fastcgi_param PATH_INFO $fastcgi_path_info;
fastcgi_param HTTPS on;
#Avoid sending the security headers twice
fastcgi_param modHeadersAvailable true;
fastcgi_param front_controller_active true;
fastcgi_pass $socket;
fastcgi_intercept_errors on;
location ~ ^/(?:updater|ocs-provider)(?:$|/) {
try_files $uri/ =404;
index index.php;
# Adding the cache control header for js and css files
# Make sure it is BELOW the PHP block
location ~* \.(?:css|js|woff|svg|gif)$ {
try_files $uri /index.php$uri$is_args$args;
add_header Cache-Control "public, max-age=7200";
# Optional: Don't log access to assets
access_log off;
location ~* \.(?:png|html|ttf|ico|jpg|jpeg)$ {
# Optional: Don't log access to other assets
access_log off;
8. Go to System -> Plugins -> Tick openmediavault-mysql -> Install
9. Services -> MySQL -> Enable -> Save -> Apply
                      -> Reset Password
10. Go to https://nextcloud.com/ -> Download -> Get Nextcloud Server -> Download -> Web Installer (Bottom Tab) -> Download setup-nextcloud.php to your PC
11. Use FTP/SAMBA/etc to transfer setup-nextcloud.php to www/nextcloud/
12. Go to https://<<<DEVICE_IP>>>:91/setup-nextcloud.php
     - Please add exception for the self-signed certificate if your browser prompt you to do so
     - Next
     - Dependency check: Enter a single "." -> Next
     - Wait until: 504 Gateway Time-out
13. Go to https://<<<DEVICE_IP>>>:91/  (Retry again if you get 404)
     - Click on Storage & database -> MySQL/MariaDB
        - Database user: root
        - Database password: <<<Password Reset On Step #10>>>
        - Database name: nextcloud
        - Database host: localhost
     - Finish setup
14. Services -> Nginx -> Servers -> Edit
     - PHP -> Default config: Disable
15. Go to https://<<<DEVICE_IP>>>:91/
16. If installation failed on step #12 onwards:
     - Remove all the folders/files/hidden files in www/nextcloud/* through FTP/SAMBA/etc (Note that, removing 13,000+ files may take a while)
     - Services -> MySQL -> SQL management site -> Enable -> Save -> Apply -> Show
        - Tools -> Database Manager -> tick "nextcloud" and "DROP selected databases" -> Submit
     - Start over again from step #12
17. Setup the Dynamic DNS if you need to access your NextCloud through internet. Then, on your internet modem/router: Port Forward to the device with port 91
