User:Pineadmin/OpenMediaVault
Revision as of 10:04, 13 December 2017 by Pineadmin (talk | contribs)
If you are dealing with confidential files transfer/sharing, please make sure your setup is secured with long and hard to guess random password or PKI keys. Make sure you use DUMMY folders/files for testing first to get yourself familiar and comfortable with the settings.
Basic Setup
1. If no output on HDMI, you need to find the IP Address with tools (e.g. netscan) (hostname: ROCK64, PINE64, PINE64SO)
2. Use the IP Address on PC browser to login to the Web Admin Pages: admin / openmediavault  (Remember to change the default password: System -> General Settings -> Web Administrator Password)
3. You may want to use Static IP for easy access in future: System -> Network -> Interfaces -> Edit or Add(Ethernet)
Shared Folders
1. Plug Hard Drive
2. Go to Storage -> Physical Disks -> Scan
3. Go to Storage -> File Systems -> select the Partition to mount -> Mount -> Apply
4. Access Right Management -> User -> Add (Make sure it is under "users" Group)
5. Access Right Management -> Shared Folders -> Add
    - select newly added Shared Folder -> Privileges -> tick Read/Write -> Save -> Apply
                                       -> ACL (for ext3/ext4 filesystem) -> tick Read/Write -> Save -> Close
FTP
1. Go through the "Basic Setup" and "Shared Folders" above
2. Services -> FTP -> Settings -> Enable -> Save -> Apply
                   -> Shares -> Add -> Apply
If you constantly hit by "Permission denied", then you may consider a less secure solution: Services -> FTP -> Settings -> Permit root login (enable)
This may happen when your hard drive is using FAT/FAT32 file system where permission cannot be set and after reboot, the default read only permission is used
SAMBA (Windows Share)
2. Services -> SMB/CIFS -> Settings -> Enable -> Save -> Apply
NFS
2. Services -> NFS -> Settings -> Enable -> Save -> Apply
To access from Kodi/XBMC, use "insecure" instead of "secure" on "Extra options"
Rsync (Clone/Backup)
You required 2 devices (e.g. 2 ROCK64, PINE64, SOPINE or etc) to Clone/Backup from master to slave or bidirectional
2. Setup the Dynamic DNS if you need to rsync clone/backup through internet
3. [On slave/destination device]
    Services -> Rsync -> Server -> Settings -> Enable -> Save -> Apply
                                -> Modules -> Add -> General
     - Make sure to choose correct "User"
     - Enable "Authenticate users"
     - Fill in "Hosts allow" for more security
                                                  -> User -> Add
4. Services -> Rsync -> Jobs -> Add (Type: Remote, Mode: Push, Destination server: [USER]@[HOST]::[Rsync Server Module Name])
    - [HOST] can be <<<CNAME>>>.ddns.net for Dynamic DNS
    - for testing: select Job -> Run
    - for bidirectional Rsync: Add another Job to Pull from slave/destination device (Don't enable Delete because deleted file/folder may be copied over again)
5. Diagnostics -> System Logs
SSH
1. Go through the "Basic Setup" above
2. Services -> SSH -> Permit root login (enable)  (Remember to always disable it back for security reason)
3. SSH to the device with Putty: root / openmediavault  (Remember to change the default password)
System Monitoring
2. System -> Monitoring -> Enable -> Save -> Apply
3. Diagnostics -> System Information -> Performance statistics
Notification
2. System -> Notification -> Settings
    - Enable
    - for GMAIL
       - SMTP server: smtp.gmail.com
       - SMTP port: 587
       - Use SSL/TLS secure connection: Enable
       - Sender email: <<<Your GMAIL Address>>>
       - Authentication required: Enable
       - Username: <<<Your GMAIL Address>>>
       - Password: <<<Your GMAIL Password>>>
       - Recipient: <<<Your Recipient Emails>>>
       - at your GMAIL account, you also need to enable: GMAIL -> Settings -> Accounts and Import -> Change account settings -> Other Google Account settings -> Sign-in & security -> Apps with account access -> Allow less secure apps: ON
    - Save -> Apply
    - use "Send a test email" for testing
Wi-Fi
2. While Ethernet network cable is still plugged, plug in the USB Wi-Fi dongle and reboot the board
3. Login to the Web Admin Pages and go to System -> Network -> Interfaces -> Add(Wi-Fi)
    - General settings
       - Name: <<<Select wlan0>>>
    - Wi-Fi
       - SSID: <<<Your Wireless Router Wi-Fi SSID>>>
       - Password: <<<Your Wireless Router Wi-Fi Password>>>
    - IPv4
       - Method: DHCP or Static
4. Save -> Apply
5. Unplug Ethernet network cable and reboot the board
Dynamic DNS
[YOU CAN SKIP THIS IF YOU KNOW HOW TO SETUP DYNAMIC DNS ON YOUR INTERNET MODEM/ROUTER]
2. SSH to the board
3. # apt-get install ddclient  (no-ip.com example)
Dynamic DNS service provider: other
Dynamic DNS server: dynupdate.no-ip.com
Dynamic DNS update protocol: dyndns2
Username for dynamic DNS service: <<<USERNAME/EMAIL>>>
Password for dynamic DNS service: <<<PASSWORD>>>
Re-enter password to verify: <<<PASSWORD>>>
Network interface used for dynamic DNS service: web
DynDNS fully qualified domain names: <<<CNAME>>>.ddns.net
Run ddclient on PPP connect? No
Run ddclient as daemon? Yes
Interval between ddclient runs: 300
# dpkg-reconfigure ddclient  (To Re-run configuration wizard above)
4. # vi /etc/ddclient.conf
Change: use=if, if=web
To:     use=web, web=checkip.dyndns.com, web-skip='Current IP Address'
protocol=dyndns2
server=dynupdate.no-ip.com
login=<<<USERNAME/EMAIL>>>
password='<<<PASSWORD>>>'
5. # systemctl restart ddclient  (Restart ddclient after changed in configuration)
6. Diagnostics:
# ddclient -daemon=0 -debug -verbose -noquiet
# systemctl status ddclient
7. On your internet modem/router: Port Forward to the slave/destination device with port 873.
