User:Pineadmin/OpenMediaVault
Revision as of 07:45, 5 December 2017 by Pineadmin (talk | contribs)
If you are dealing with confidential files transfer/sharing, please make sure your setup is secured with long and hard to guess random password or PKI keys. Make sure you use DUMMY folders/files for testing first to get yourself familiar and comfortable with the settings.
Basic Setup
1. If no output on HDMI, you need to find the IP Address with tools (e.g. netscan) (hostname: ROCK64, PINE64, PINE64SO)
2. Use the IP Address on PC browser to login to the Web Admin Pages: admin / openmediavault  (Remember to change the default password: System -> General Settings -> Web Administrator Password)
3. You may want to use Static IP for easy access in future: System -> Network -> Interfaces -> Edit or Add
4. Plug Hard Drive
5. Go to Storage -> Physical Disks -> Scan
6. Go to Storage -> File Systems -> select the Partition to mount -> Mount -> Apply
7. Access Right Management -> User -> Add (Make sure it is under "users" Group)
8. Access Right Management -> Shared Folders -> Add
    - select newly added Shared Folder -> Privileges -> tick Read/Write -> Save -> Apply
FTP
1. Go through the "Basic Setup" above
2. Services -> FTP -> Settings -> Enable -> Save -> Apply
                   -> Shares -> Add -> Apply
If you constantly hit by "Permission denied", then you may consider a less secure solution: Services -> FTP -> Settings -> Permit root login (enable)
This may happen when your hard drive is using FAT/FAT32 file system where permission cannot be set and after reboot, the default read only permission is used
Rsync Clone/Backup
You required 2 devices (e.g. 2 ROCK64, PINE64, SOPINE or etc) to Clone/Backup from master to slave or bidirectional
2. [On slave/destination device]
    Services -> Rsync -> Server -> Settings -> Enable -> Save -> Apply
                                -> Modules -> Add -> General
     - Make sure to choose correct "User"
     - Enable "Authenticate users"
     - Fill in "Hosts allow" for more security
                                                  -> User -> Add
3. Services -> Rsync -> Jobs -> Add (Type: Remote, Mode: Push, Destination server: [USER]@[HOST]::[Rsync Server Module Name])
    - for testing: select Job -> Run
    - for bidirectional Rsync: Add another Job to Pull from slave/destination device (Don't enable Delete because deleted file/folder may be copied over again)
4. Diagnostics -> System Logs
Rsync Clone/Backup (Through Internet)
[IF YOU KNOW HOW TO SETUP DYNAMIC DNS ON YOUR INTERNET MODEM/ROUTER PLEASE SKIP TO #8]
2. Services -> SSH -> Permit root login (enable)  (Remember to always disable it back for security reason)
3. SSH to the device with Putty: root / openmediavault  (Remember to change the default password)
4. # apt-get install ddclient  (no-ip.com example)
Dynamic DNS service provider: other
Dynamic DNS server: dynupdate.no-ip.com
Dynamic DNS update protocol: dyndns2
Username for dynamic DNS service: <<<USERNAME/EMAIL>>>
Password for dynamic DNS service: <<<PASSWORD>>>
Re-enter password to verify: <<<PASSWORD>>>
Network interface used for dynamic DNS service: web
DynDNS fully qualified domain names: <<<CNAME>>>.ddns.net
Run ddclient on PPP connect? No
Run ddclient as daemon? Yes
Interval between ddclient runs: 300
# dpkg-reconfigure ddclient  (To Re-run configuration wizard above)
5. # vi /etc/ddclient.conf
Change: use=if, if=web
To:     use=web, web=checkip.dyndns.com, web-skip='Current IP Address'
protocol=dyndns2
server=dynupdate.no-ip.com
login=<<<USERNAME/EMAIL>>>
password='<<<PASSWORD>>>'
6. # systemctl restart ddclient  (Restart ddclient after changed in configuration)
7. Diagnostics:
# ddclient -daemon=0 -debug -verbose -noquiet
# systemctl status ddclient
8. On your internet modem/router: Port Forward to the slave/destination device with port 873.
9. [On slave/destination device]
                                                  -> User -> Add
10. Services -> Rsync -> Jobs -> Add (Type: Remote, Mode: Push, Destination server: [USER]@[<<<CNAME>>>.ddns.net]::[Rsync Server Module Name])
11. Diagnostics -> System Logs
SSH
SAMBA (Windows Share)
2. Services -> SMB/CIFS -> Settings -> Enable -> Save -> Apply
NFS
2. Services -> NFS -> Settings -> Enable -> Save -> Apply
To access from Kodi/XBMC, use "insecure" instead of "secure" on "Extra options"
System Monitoring
2. System -> Monitoring -> Enable -> Save -> Apply
3. Diagnostics -> System Information -> Performance statistics
