User:Pineadmin/OpenMediaVault
Revision as of 03:34, 22 November 2017 by Pineadmin (talk | contribs)
If you are dealing with confidential files transfer/sharing, please make sure your setup is secured with long and hard to guess random password or PKI keys
Basic Setup
1. If no output on HDMI, you need to find the IP Address with tools (e.g. netscan) (hostname: PINE64, PINE64SO)
2. Use the IP Address on PC browser to login to the Web Admin Pages: admin / openmediavault  (Remember to change default password: System -> General Settings -> Web Administrator Password)
3. Plug USB Drive
4. Go to Storage -> Physical Disks -> Scan
5. Go to Storage -> File Systems -> select the Partition to mount -> Mount -> Apply
6. Access Right Management -> User -> Add
7. Access Right Management -> Shared Folders -> Add
    - select newly added Shared Folder -> Privileges -> tick Read/Write -> Save
FTP
1. Complete the "Basic Setup" above
2. Services -> FTP -> Settings -> Enable -> Save -> Apply
                   -> Shares -> Add -> Apply
Rsync Clone/Backup
You required 2 devices (e.g. 2 ROCK64, PINE64, SOPINE or etc) to Clone/Backup from master to slave or bidirectional(Not fully tested).
2. [On slave/destination device] Services -> Rsync -> Server -> Settings -> Enable -> Save -> Apply
	                                                     -> Modules -> Add -> General then User -> Add
3. Services -> Rsync -> Jobs -> Add (Type: Remote, Mode: Push, Destination server: [USER]@[HOST]::[Module])
    - for testing: select Job -> Run
    - for bidirectional Rsync: Add another Job to Pull from slave/destination device (Don't enable Delete because new file/folder will be deleted)
4. Diagnostics -> System Logs
Rsync Clone/Backup (Through Internet)
TBD
