Nutcracker
Jump to navigation
Jump to search
PAGE UNDER CONSTRUCTION, INFO SUBJECT TO CHANGE
- BL-602 EVB (Evaluation Board):
Contents
BL602 Specifications
- CPU: 32-bit RV32IMAFC RISC-V “SiFive E24 Core”
- Memory:
- 128KB Flash
- 32KB SRAM
- DC in (only one of the following at a time):
- 12V- 24V DC5525 Barrel Jack
- USB-C 12-20V PD
- QC3.0
Pinecil board information, schematics and certifications
- Pinecil mainboard schematic:
- Pinecil mainboard schematic ver 1.0 20201015
- Pinecil mainboard ver 1.0 PCB Component Placement Top PDF file
- Pinecil mainboard ver 1.0 PCB Component Placement Bottom PDF file
- Pinecil mainboard ver 1.0 PCB Component Placement Top Drawing file
- Pinecil mainboard ver 1.0 PCB Component Placement Bottom Drawing file
- Pinecil breakout board schematic:
- Pinecil certifications:
Pinecil tips
- Default tip model TS-B2 accompany with Pinecil
- Uses TS-100 compatible tips
- GigaDevice RISC-V SoC information:
- Display Module information:
- USB Type-C PD Controller information:
- Sensor information:
- Power Regulator information:
- Power MOSFET Switch information:
- OP Amp information:
Development efforts
Project Homepage | Project Source | Implementations | |
Ralimtek | https://ralimtek.com | https://www.gitmemory.com/Ralim |
