Main Page
What You’ll Need to Get Started
You will need the following to get started with using your Pine A64 or A64+ board:
  • Windows / Linux PC or MAC with a SD Card Reader connected to the Internet
  • Power Supply (PSU) and a micro usb cable. Please make sure to use a PSU rated at +5V @2A and a micro USB cable that is at least 26 AWG thick.
  • MicroSD card (8GB or higher capacity) rated 'class 10' or better.
  • HDMI cable (unless you wish to run headless/ without a monitor). N.B. Android and Remix OS support 720p and 1080p, while Linux supports a wider range of resolutions.
  • Input device(s) such as: keyboard, mouse, remote, pointer, etc,.
Step by Step Instructions
Caution!
Please handle the Pine A64 or A64+ with care. Always hold the board by the edges and make sure to wear an antistatic wrist strap when handling the Pine A64 (+). Touching components on the front and back of the board can result in an ESD discharge that may damage your board. Avoid placing the board on materials such as carpets, plastics or other surfaces prone to electrostatic build-up.
You will require a quality microSD card (8GB or greater; class 10 or faster). There are many substandard and counterfeit cards in circulation and even reputable vendors may unknowingly sell counterfeit microSD cards. Cards that do not meet the criteria outlined above are known to cause a variety of issues including, but not limited to, complete boot failure. There are ways of testing microSD cards prior to installing the operating system to make sure they are appropriate for use with your board. The main utility for checking microSD cards is H2testw 1.4; yet another alternative is F3.
Having successfully imaged your microSD card, insert it into the microSD slot located at the bottom left of the board / to the left of the USB 2.0 sockets.
Plug in the HDMI Cable, Ethernet Cable and Peripherals
Unless you are planning on running your Pine A64 (+) headless (without a monitor / as a server), you should plug in all necessary peripherals, including the HDMI and Ethernet cable, prior to powering on the board. Do note, depending on which OS image you are using, some peripherals may or may not work. N.B. Some HDMI→DVI/ VGA converters may not work in conjunction with your monitor or TV.
Apply Power to Your Board
Once you have imaged your microSD and plugged everything in, you are ready to apply power to the Pine A64(+) board. You'll need a good quality 5 Volt, 2 Amp PSU. Using a good quality PSU and micro USB cable is very important as failing to meet the required specifications may prevent the board from booting correctly. A marginally higher PSU Voltage is acceptable (for instance, 5.1 volts - due to the nature of the micro usb connection, a 5.1v supply can help protect slightly against voltage drops which can cause undesirable results). However, a significantly higher voltage of 7 Volts or more will damage the Pine A64(+) board and may render it inoperative.
If you are using a separate micro USB cable with your PSU, make sure that the cable has a low resistance rating. Cables with high resistance will cause improper function and the unit may not boot at all or only partially. The thicker the internal cabling, the better i.e. AWG (American Wire Gauge) 20 is better than AWG 28. In General, power-only microUSB cables come with red colour USB header.
Having completed the steps outlined above the Pine A64(+) board will begin to boot. The red onboard LED light indicates power on status. The LED will not blink during boot up and the colour of the LED stays solid. The colour does not change to signify an error.
  • A compression Utility (used to unarchive the OS image). We recommend you use 7zip.
  • A disk image utility (used to ‘burn’ the .img to your SD card). We recommend you use either the Win32Imager or Etcher utility.
Optional
  • Phoenix Card image utility (used ONLY for phoenix card images). You can download it from here.
You can find all curated OS images under #Curated Pine A64 (A64+) OS Images. There are two type of Android and Remix images available. Images designated ‘DD’ need to be imaged using Etcher or Win32imager, whilst images labelled ‘Phoenix Card Image’ require the Phoenix Card utility.
Having downloaded the required OS image proceed to use 7zip to unarchive it by right-clicking the archive, and sellecting ‘Extract All’. Upon completion, note the destination of where the .img file was extracted (‘Downloads’ folder by default). Once the process has completed, you can proceed to imaging the .img file.
Imaging the microSD card (DD)
  • Launch Win32diskImager.exe or etcher.exe. You will be presented with a field titled ‘path’ and a drop down menu labeled ‘device’. Click the ‘path’, navigate to and select the OS image you extracted from the archive earlier. Next, from the drop-down menu select the drive your microSD has been assigned. N.B. Pay close attention to the selected drive (remember your letter) – the imaging process will format the selected drive. If you choose the wrong drive all your data will be lost.
Imaging using Phoenix Card
  • Launch phoenixcard.exe. You will be presented with a ‘disk’ drop-down menu and a field denoted as ‘Img File’. Click on ‘Img File’ and navigate to and select the OS image have downloaded and unarchived. Next, make sure to select the disk that your microSD card has been assigned. N.B. Pay close attention to the selected drive (remember your letter) – the imaging process will format the selected drive. If you choose the wrong drive all your data will be lost.
Imaging microSD on Apple OSX
  • A compression Utility (used to unarchive the OS image). We recommend you use 7Zip.
  • A disk image utility (used to ‘burn’ the .img to your SD card in GUI). We recommend you use ApplePi Baker or Etcher.
N.B. Phoenix Card utility and images are NOT available on Apple OSX.
You can find all curated OS images under #Curated Pine A64 (A64+) OS Images. On OSX you can only use images designated as ‘DD’.
Imagining the microSD card (GUI)
  • Insert your microSD card into your Mac laptop/USB card reader. You may require a SD → microSD converter, as Apple’s laptops and desktops only feature a full-size SD card reader. Once the microSD card is plugged into your computer it should appear in Finder / on your desktop.
  • Launch Apple-Pi Baker or the etcher utility. Upon startup the application it will ask for your password. When the application launches you will be presented with a field titled ‘IMG file’ and a path of the mounted microSD card (it will look something like this: ‘/dev/diskX 32.0Gb SD card’). Click the ‘IMG file’ button, navigate to and select the OS image you extracted from the archive earlier. Next, select the microSD from the window. N.B. Pay close attention to the selected drive – the imaging process will format the selected drive. If you choose the wrong drive all your data will be lost.
  • Having chosen the desired OS image and the correct driver press ‘Restore Backup’. Once the image has been written to your microSD card you will receive a pop-up notification. Be sure to close the application and to eject/remove your SD card safely from your Mac.
Imaging from Terminal
N.B. If you are not comfortable using the terminal, please use the GUI method outlined above instead.
  • Open up your terminal and navigate to the directory where you unarchived your OS image.
  • Before you start writing to the card, you will have to identify your microSD card. Type: diskutil list and note the output. The disk number should match the size of your SD card and will likely be using ‘Fdisk_partition_scheme’. Having identified the disk number execute the following commands (substitute diskX for your disk and name of image for pine64-image-name.img):
diskutil unmountDisk /dev/diskX sudo dd if=pine64-image-name.img of=/dev/disk2 bs=1M
  • Wait patiently for the process to complete. Be sure to eject/remove your SD card safely from your Mac.
Troubleshooting
There is a number of things that can prevent the Pine A64(+) board from booting up properly. The most common culprits of a failed boot are (to find out more click here):
  • Subpar Power Supply
  • Failed imaging of the microSD card (refer to the respective ‘imaging microSD card section)
Make sure to have the newest version of the OS image your are running. On Linux, you can update the kernel and uboot using scripts located in the following directory: /usr/local/sbin
To navigate to the directory type (in terminal): cd /usr/local/sbin
You list all the available scripts by typing (in terminal): ls
To run the script required update script run the following command: sudo ./update_script.sh (substitute the relevant update script for update_script)
Supported Screen Resolutions
The pine supports a number of video resolutions under Linux, however RemixOS and Android images currently only support 720p and 1080p. Linux supports a wider range of resolutions (see all resolutions supported on Linux here). If the native resolution of your monitor or TV is not compatible with the Pine A64(+) then you will be unable to get a video to work with your screen.
Troubleshooting Step by Step
  • Check your PSU and microUSB cable ratings
  • Plug in Power and Ethernet into your Board
  • Check your router for Pine A64(+) IP
  • Attempt to ssh into the Pine A64(+) from your computer
If your PSU and microUSB meet the criteria, and you have correctly followed the instructions to image your card and power on the board, but you are not seeing any LED activity and cannot ssh into your Pine A64(+) then either the imaging process failed (possibly due to a subpar microSD) OR the PSU / microUSB cable is/are faulty.
If your PSU and microUSB meet the criteria, and you have correctly imaged the OS to your card and power on the board and your can ssh into your Pine A64(+) but get no video feed, then it's likely that the native resolution of your monitor/TV is not supported.
If neither of the abovementioned scenarios fits the problem you are facing please consult this thread (thanks to Ghost for compiling the list): http://forum.pine64.org/showthread.php?tid=680
Debian Jessie
  • Debian Jessie Linux by Lenny Raposo (Longsleep kernel 3.10.102 BSP 2)
Ubuntu 16.04
  • Ubuntu Linux Image by Longsleep (3.10.xxx)
    • Thanks to longsleep's work, the Linux build progress rapidly. For latest build please see this thread
    • Suitable for 1GB/2GB Pine A64+ Board, not suitable for 512MB Pine A64 Board due to system memory constrain
    • DD image (for 8GB and above SD Card):
    • To install Mate desktop run: sudo /usr/local/sbin/install_mate_desktop.sh
    • Login with
      • username: ubuntu
      • password: ubuntu
    • Execute resize_rootfs.sh script to resize the root partition in order to fully utilize the SD Card
Android 5.1.1
  • Android 5.1.1 Image Release 20160711 [v1.2.6]
    • The Android build is suitable for 1GB/2GB Pine A64+ Board but not advised to run on a 512MB Pine A64 Board due to system memory constraints.
    • Rootable build, online update (OTA) only work when the build still not root.
    • Set default HDMI output to 720P, video setting supports both 720P and 1080P
    • Add Ethernet Network setting.
    • Update GMS software package to 5.1r4
    • Set UVC USB camera as front camera and 5M Pixel camera module as real camera
    • DD images:
Remix OS 2.0
  • Remix OS 2.0 Image Release 20160718
    • Suitable for 2GB Pine A64+ Board, can runs on 1GB Pine A64+ Board with performance lagging, not suitable for 512MB Pine A64 Board
    • Add Remix apps market
    • Video setting supports both 720P and 1080P
    • Supports video screen scaling function
    • New MAC address assignment method, tags to board and SoC unique ID.
    • Support UVC USB camera as front camera
    • Known issues:
      • Not yet support 5M Pixel camera module as real camera
      • Even the HDMI output can set to 720P, but during boot up time, the boot logo stil maintain as 1080P.
    • DD image (for 8GB microSD Card):
Under the 'Pine A64 Software and OS Image Download Section' you can find a complete list of currently supported Operating System images that work with the Pine A64 as well as other related software. The list includes OS images and descriptions of:
  • Debian Jessie
  • Arch Linux
  • Ubuntu 16.04
  • Remix OS
  • Android 5.1
  • Android 7.0
  • Windows IoT
  • OpenHAB
Provided are also H2testw 1.4 and F3 utilities used for checking microSD card performance, Allwinner's Phoenix Card bootable OS utility and other useful software.
Under 'Guides for Pine A64 accessories' you can find instructions and guides pertaining to:
  • Enclosures
  • Bluetooth and WiFi module
  • Real Time Clock (RTC) battery
  • Real Time Clock (RTC) battery holder
  • First and third party cases
  • Featured 3D printed cases (and more).
SoC and Memory Specification
  • Based on Allwinner A64
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • RAM Memory Variants: 512MB, 1GB and 2GB.
  • Storage Memory: Pine A64 boards do not have built-in Flash memory but use bootable microSD Cards or USB attached storage.
Board Features
Video
  • HDMI 1.4a (Type A - full)
Audio
Network
  • 10/100/1000Mbps Ethernet(Pine A64+ version), 10/100Mbps Ethernet(Pine A64 version)
Storage
  • USB - 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • 2x17 pins "Euler" GPIO Header
  • 2x5 pins "EXP" Console Header
Pine A64 Board Information and Schematics
Pine A64 POT
Other Resources
