Main Page
Freshman Page [A.K.A. Quick Start Guide]
Needed:
  • Pine A64 or A64+ board
  • Power Supply (PSU and micro USB cable), make sure spec at +5V @2A
  • MicroSD card, 8GB and above, speed at least class 10. Per tkaiser input, high random I/O performance is an important factor when selecting microSD card.
  • HDMI cable except for headless build
  • Input device(s) - (keyboard, mouse, remote, pointer, etc)
Steps:
  1. Firstly, be careful handling the Pine A64 board to make sure it is not subjected to electrostatic discharge. Wearing and correctly utilizing a grounding strap can help to mitigate the risks of ESD. At any rate, handle the board at the edges, avoid touching components on the board, and place on a safe surface (avoid carpets and any other material that is prone electrostatic build-up).
  2. Then you'll need a reliable 5 volt, 2 amp (or higher) power supply. This is very important. If the amperage rating of the power supply is too low, the board will not boot properly. A marginally higher voltage for the PSU is ok (such as 5.1 volts - due to the nature of the micro usb connection, a 5.1v supply can help protect slightly against voltage drops which can cause undesirable function), but a significantly higher voltage more than 7 volt will damage the Pine A64 board and may render it inoperative.
  3. If using a power supply with a separate micro USB cable, make sure to use a cable with low resistance. Cables with high resistance will cause improper function and the unit may have trouble booting up. The thicker the internal cabling, the better (i.e. AWG (American Wire Gauge) 20 is better than AWG 28). In General, the power-only micro USB cable comes with red color USB header.
  4. You will also need a decent microSD card. There are many sub-standard and fake microSD cards in circulation, and using just such a card will cause issues booting up. There are ways of testing microSD cards prior to installing the operating system to make sure they are ok for use. The main one is H2testw 1.4 or another alternative is F3.
  5. Next, you'll want a decent HDMI cable. As with micro USB cabling, quality of HDMI cable can vary a lot, so try and go for quality rather than cheapness. If you are using a HDMI to VGA/DVI adapter, be aware that some work better than others.
  6. Finally, you will want to have a way of controlling the on-screen cursor and of typing, thus you will need a keyboard, mouse, touchpad/trackpad, or some kind of combo device that combines these two things.
  7. After you have all the physical things you need, you will need to download and install the operating system to microSD card. Using Win32 Disk Imager in Windows, or via the dd command in Unix-based systems to burn the microSD card.
  8. The onboard LED light just indicate power on status, LED will not blink during boot up or encounter error.
Recommended OS build DD image for Freshman
  • Using 8GB class 10 microSD card
File:8GB microSD.jpg
  • Setup Steps:
  1. Download the preferred OS image from below OS links and extract the img file from the archive using 7-Zip
  2. Use Win32 Disk Imager or Linux dd command to write the img to a SD card
  3. Insert the SD card into Pine A64 board and boot it up
Debian Linux Jessie with Mate GUI Image [20160701] by lenny.raposo with Longsleep kernel
File:Logo debian.jpg
Ubuntu Linux Image [20160530] based on Longsleep build, updated by Pine64
File:Logo ubuntu.jpg
  • Thanks to longsleep works, the Linux build progress rapidly, This is a build based on longsleep works and may not have all bell and whistles from longsleep and Sunxi community. For latest build, you can create one and following this thread
  • Suitable for 1GB/2GB Pine A64+ Board, not suitable for 512MB Pine A64 Board due to system memory constrain
  • DD image (for 8GB and above SD Card):
  • Included Mate Desktop, Firebox Browser, Thunderbird Email, and LibreOffice Suite.
  • Login with
    • username: ubuntu
    • password: ubuntu
  • Execute resize_rootfs.sh script to resize the root partition in order to fully utilize the SD Card
Android 5.1.1 Image Release 20160711 [v1.2.26]
File:Logo android lollipop.jpg
  • The Android build suitable for 1GB/2GB Pine A64+ Board, not advise to run on 512MB Pine A64 Board due to system memory constrain
  • Rootable build, online update (OTA) only work when the build still not root.
  • Set default HDMI output to 720P, video setting supports both 720P and 1080P
  • Add Ethernet Network setting.
  • Update GMS software package to 5.1r4
  • Set UVC USB camera as front camera and 5M Pixel camera module as real camera
  • DD images:
Remix OS 2.0 Image Release 20160718
  • Suitable for 2GB Pine A64+ Board, can runs on 1GB Pine A64+ Board with performance lagging, not suitable for 512MB Pine A64 Board
  • Add Remix apps market
  • Video setting supports both 720P and 1080P
  • Supports video screen scaling function
  • New MAC address assignment method, tags to board and SoC unique ID.
  • Support UVC USB camera as front camera
  • Known issues:
    • Not yet support 5M Pixel camera module as real camera
    • Even the HDMI output can set to 720P, but during boot up time, the boot logo stil maintain as 1080P.
  • DD image (for 8GB microSD Card):
SoC Specification
  • Based on Allwinner A64
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • Main Memory Option: 512KB, 1GB and 2GB.
  • Storage Memory: No build in Flash memory, fully base on bootable microSD Card or USB attached storage.
Board Features
Video
  • HDMI 1.4a (Type A - full)
Audio
Network
  • 10/100/1000Mbps Ethernet(Pine A64+ version), 10/100Mbps Ethernet(Pine A64 version)
Storage
  • mricoSD - bootable, support SDHC and SDXC, storage up to 256GB
  • USB - 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • 2x17 pins "Euler" GPIO Header
  • 2x5 pins "EXP" Console Header
Power Usage
  • Input Power: DC 5V @ 2A, 3.7V Li-Ion battery connector, microUSB connector, Euler connector
  • Power Consumption: 2.5W
Software/Image Download
Board Dimension
  • 133mm x 80mm x 19mm
Pine A64 Hardware PCB information
Datasheet
Pine A64 POT
Related Information
Other Resources in the Net
