User:Pineadmin/Lakka
Revision as of 05:01, 15 December 2017 by Pineadmin (talk | contribs)
Gamepad
- On Lakka menu
   - When plugged in Gamepad, it is normal that the menu will navigate up and down randomly
   - Use Up key on right keypad to search. Down key to delete and Start key (middle right button) to start search
- Start key (middle right button) and Right key on right keypad are used most frequently to select or start/pause game. Down key on right keypad is used to back or cancel. Some keys combination are still depend on the game.
- Tested Sony Playstation Gamepad (Dualshock 3): Press on the Playstation button (middle) on the Gamepad to start using the Gamepad
   - For bluetooth
      - Plug the bluetooth USB dongle to the board
      - Plug the Gamepad USB cable to the board and go to Settings -> Services -> Bluetooth Enable: ON
      - Then unplug the USB cable and press on the Playstation button (middle) on the Gamepad and wait for the bluetooth connection (You may need to try few times)
      - For more information please visit http://www.lakka.tv/doc/Wireless-Dualshock/
- Tested Logitech Dual Action Gamepad
Scan Multiple Game ROMs
1. Plugged in USB Drive with ROMs
2. Main Menu -> Load Content -> Collections -> Scan Directory ->
    OR
   Import content (Far right of the menu) -> Scan Directory -> <<<My Hardisk>>> -> <<<Navigate to the ROMs folder>>> -> <Scan This Directory>
3. If newly scanned game not showing on the menu, then try reboot
Stop Game
- Press down both Left/Right Analog (Rounded) Joystick (L3 + R3) at the same time -> Close Content
   - OR can directly use Esc on normal keyboard to force stop
- Press again to resume
- L3 + R3 settings can be found on: Settings -> Input -> Menu Toggle Gamepad Combo
Screenshot
- Press down both Left/Right Analog (Rounded) Joystick (L3 + R3) at the same time -> Take Screenshot
- The screenshot image files will be saved in Screenshots folder (/storage/screenshots)
Enable Samba
- Settings -> Services -> SAMBA Enable -> ON
- To check the IP Address: Main Menu -> Information -> Network Information -> Interface (eth0)
- [www.lakka.tv/doc/BIOSes/ Bios] files can be copied to System folder (/storage/system)
Enable SSH
- Settings -> Services -> SSH Enable -> ON
- The default root password is: root
   - If you plan to enable SSH for longer period, you should disable password authentication in ssh and use public key authentication as advice by the "passwd" command
