User:Pineadmin/Lakka
Revision as of 07:26, 28 November 2017 by Pineadmin (talk | contribs) (Created page with " == Gamepad == <pre<noinclude></noinclude> style="white-space: pre-wrap; white-space: -moz-pre-wrap; white-space: -pre-wrap; white-space: -o-pre-wrap; word-wrap: break-word;"...")
Gamepad
- When plugged in gamepad, it is normal that the menu will navigate up and down randomly
- Tested Sony Playstation3 Gamepad: Press on the Playstation button on the Gamepad to start using the Gamepad
- Tested Logitech Dual Action Gamepad
Scan Multiple Game ROMs
1. Plugged in USB Drive with ROMs
2. Main Menu -> Load Content -> Collections -> Scan Directory ->
    OR
   Import content (Far right of the menu) -> Scan Directory -> <<<My Hardisk>>> -> <<<Navigate to the ROMs folder>>> -> <Scan This Directory>
3. If newly scanned game not showing on the menu, then try reboot
Stop Game
- Press down both Left/Right Analog (Rounded) Joystick (L3 + R3) at the same time -> Close Content
   - OR can directly use Esc on normal keyboard to force stop
- L3 + R3 settings can be found on: Settings -> Input -> Menu Toggle Gamepad Combo
Screenshot
- Press down both Left/Right Analog (Rounded) Joystick (L3 + R3) at the same time -> Take Screenshot
- The screenshot image files will be saved in /storage/screenshots
Enable Samba
- Settings -> Services -> SAMBA Enable -> ON
- To check the IP Address: Main Menu -> Information -> Network Information -> Interface (eth0)
