Guide:Connecting to your device with SSH
Revision as of 11:40, 21 August 2017 by Ptheven (talk | contribs)
Connecting to your Device via SSH
How you connect via SSH depends on what OS you are using as a client (the device you want to SSH From). The server in this case is the Rock 64 Board.
The username/password of the Rock64 OS will depend on which OS you've downloaded and flashed:
ROCK64_Main_Page
Windows:
If you use Windows, it doesnt have an SSH client installed, you'll need to download one to SSH into the Rock 64.
Here is one such program:
https://www.fastcomet.com/tutorials/gett...rted/putty
However, for step 2, you'll need to insert the IP address of the Rock 64 ou found in the previous post: In my example it was 192.168.1.128. Yours will likely be different.
You should have it looking somewhat similar to this:
Click on "Open" to start initiating a SSH connection. You might get a warning message about a RSA key.
Its not important at this stage, since it is over a local connection and you have physical access to the hardware. Accept the connection.
Once you accept the connection, you'll be prompted to insert a Username/Password. This depends on the OS image you downloaded, its available on the Wiki Link. In My case, the image is the "Xenial Mate" image, so the username/password is rock64/rock64. Its normal to not see the password being typed in, this is a security feature.
If everything goes well, you should now be logged into your Board, and the display should look something like this:
That means you're in and you can issue commands and communicate with your board via SSH!
Mac OS:
I dont have a Mac OS device to test this out on, but the process is much more simpler on Mac OS and Linux than windows.
http://osxdaily.com/2017/04/28/howto-ssh-client-mac/
In this scenario, the string:
ssh username@ip.address
Would look like
ssh rock64@192.168.1.128
Again, this depends on which Image was downloaded and what the IP address is.
Linux:
Very similar to the MacOs guide. Open your favourite terminal emulator installed in your distro and enter the credentials and thats all there is to it!
Further reading: https://help.ubuntu.com/community/SSH/Op...nnectingTo
