File:USB C PD shared watts charger.jpg
Revision as of 01:22, 24 February 2023 by River (talk | contribs)
Summary
Many multi-port chargers share the total watts across all the ports. This means to get the full 20V 3.25a PD65w on these chargers, then only a single port can be used at a time. Plugging in Pinecil and other things to the other ports would limit the power going to Pinecil and reduce the volts from for example 20V to something lower.
File history
current01:22, 24 February 2023Thumbnail for version as of 01:22, 24 February 2023469 × 389 (48 KB)River (talk | contribs)Many multi-port chargers share the total watts across all the ports. This means to get the full 20V 3.25a PD65w on these chargers, then only a single port can be used at a time. Plugging in Pinecil and other things to the other ports would limit the power going to Pinecil and reduce the volts from for example 20V to something lower.
