Revision as of 20:31, 2 July 2022 by Earboxer (talk | contribs) (This is only an example of installing the shim. If you lift up the USB-C Side Board PCB without unsticking the PCF, you may damage the connection between the two.)
Original file(1,049 × 1,669 pixels, file size: 550 KB, MIME type: image/jpeg)
Summary
File history
current20:31, 2 July 2022Thumbnail for version as of 20:31, 2 July 20221,049 × 1,669 (550 KB)Earboxer (talk | contribs)This is only an example of installing the shim. If you lift up the USB-C Side Board PCB without unsticking the PCF, you may damage the connection between the two.
