File:Braveheart VBUS 1 from diode.jpg
Revision as of 11:38, 13 February 2020 by Gab (talk | contribs) (Show 0.3mm insulated wire taking VBUS_1 (VBUS unprotected from overvoltages) from diode. See OVP component in PDF "PinePhone USB-C small board top placement v1.0 20190730.pdf". This file replaces https://wiki.pine64.org/index.php/File:Photo592000202583...)
Original file(1,280 × 960 pixels, file size: 177 KB, MIME type: image/jpeg)
Show 0.3mm insulated wire taking VBUS_1 (VBUS unprotected from overvoltages) from diode. See OVP component in PDF "PinePhone USB-C small board top placement v1.0 20190730.pdf". This file replaces https://wiki.pine64.org/index.php/File:Photo5920002025830069068.jpg wich had a bad name
File history
current11:38, 13 February 2020Thumbnail for version as of 11:38, 13 February 20201,280 × 960 (177 KB)Gab (talk | contribs)Show 0.3mm insulated wire taking VBUS_1 (VBUS unprotected from overvoltages) from diode. See OVP component in PDF "PinePhone USB-C small board top placement v1.0 20190730.pdf". This file replaces https://wiki.pine64.org/index.php/File:Photo592000202583...
There are no pages that use this file.
