Revision as of 21:03, 20 April 2023 by Fxc (talk | contribs) (Fixes)
Original file(925 × 185 pixels, file size: 19 KB, MIME type: image/png)
Summary
Arguments that can be used with Blisp
Examples for Pinecil v2 with the blisp706 chip
  • -c bl70x or --chip=bl70x select chip type
  • -p COM3 or --port=COM3 specify the Serial port (COM in windows, ttyACM in Linux). This example is COM3 but it could be different, check the Windows device manager).
full example .\blisp.exe write -p COM3 -c bl70x --reset .\Pinecilv2_EN.bin
File history
current20:07, 20 April 2023Thumbnail for version as of 20:07, 20 April 2023925 × 185 (19 KB)River (talk | contribs)Arguments that can be used with Blisp Examples for pinecil v2 with the blisp706 chip * -c bl70x or --chip=bl70x select chip type * -p COM3 or --port=COM3 specify the Serial port (COM in windows, ttyACM in linux). This example is COM3 but it could be different, check windows device manager). full example <code> .\blisp.exe write -p COM3 -c bl70x --reset .\Pinecilv2_EN.bin </code> Catergory: Pinecil
