Crust
Revision as of 01:53, 15 February 2021 by Aberts10 (talk | contribs)
This page is incomplete, you're welcome to improve it.
As per the README.md on the crust github:
Crust improves battery life and thermal performance by implementing a deep sleep state. During deep sleep, the CPU cores, the DRAM controller, and most onboard peripherals are powered down, reducing power consumption by 80% or more compared to an idle device.
For this to work, Crust runs outside the main CPU and DRAM, on a dedicated always-on microprocessor called a System Control Processor (SCP). Crust is designed to run on a specific SCP implementation, Allwinner's AR100.
To build crust manually with uboot you can find instructions Here.
RTC wakeups
Manual suspend
