Cross-compiling
Revision as of 21:31, 2 April 2023 by Fxc (talk | contribs) (Fixes)
The Pinephone's triple for cross-compiling is aarch64-unknown-linux-gnu.
C/++
Installing the Toolchain
Please add instructions for other distributions to this section if you know them!
First, you'll need to install the gcc cross-compilation toolchain.
On Arch Linux
 $ sudo pacman -S aarch64-linux-gnu-gcc
On Ubuntu/Debian
 $ sudo apt install gcc-aarch64-linux-gnu
On Void Linux
 $ sudo xbps-install cross-aarch64-linux-gnu
Using the Toolchain
Note: If you are trying to build an Arch Linux package with makepkg, also make sure to export CARCH=aarch64.
GNU Make
Kernel Makefile
For each invocation of make, be sure to pass the options ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- like this:
 $ make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu-
Other
If you are using a handwritten Makefile (not autogenerated by a meta-buildsystem such as meson, automake, etc.) then simply override CC and LD as you need.
automake
 $ ./configure --host=aarch64-linux-gnu
meson
See the official meson documentation on the topic. In general, the introduction is a good read for any cross-compiling novice.
Rust
In order to cross-compile Rust applications for the Pinephone, you need to have a gcc cross-compiler installed and the Rust dependencies, usually the std crate, cross compiled for the target system. A more extensive explanation can be found on https://github.com/japaric/rust-cross. This instruction is based on it's description.
Installing a GCC Cross-Compiler
The cross-compiler might have a different name depending on the operating system. Further along this instruction the name for the gcc cross-compiler will be used. Replace all occurences of $gcc_name with the name on your distribution.
For how to install the gcc cross-compilation toolchain on your distribution, please see Cross-compiling#Installing The Toolchain
Installing Rust Dependencies
The necessary dependencies can easily be installed with rustup:
 $ rustup target add aarch64-unknown-linux-gnu
OR it can be installed with multirust [Is this still accurate???]:
 $ multirust add-target nightly aarch64-unknown-linux-gnu
Compiling
rustc
When using rustc just add the two flags --target=aarch64-unknown-linux-gnu and -C linker=$gcc_name. Under Arch, this would look like:
 $ rustc --target=aarch64-unknown-linux-gnu -C linker=aarch64-linux-gnu-gcc main.rs
To test it, run the program on your Pinephone
 $ scp main user@ipadress:/home/user/Downloads
 $ ssh user@ipadress /home/user/Downloads/main
 Hello, world!
cargo
To cross-compile a project with cargo, open the folder of the project in a terminal. Then create a new folder and a file for cargo.
 $ mkdir .cargo
 $ cat >.cargo/config <<EOF
 > [target.aarch64-unknown-linux-gnu]
 > linker = "$gcc_name"
 > EOF
Then you can compile it with
 $ cargo build --target=aarch64-unknown-linux-gnu
To test it, copy the file on your Pinephone
 $ scp target/aarch64-unknown-linux-gnu/debug/main user@ipadress:/home/user/Downloads
Then you can execute it by
 $ ssh user@ipadress ./main -h
 Hello, world!
Possible Errors
If you encounter an error saying
 Cross compilation detected. Use PKG_CONFIG_ALLOW_CROSS=1 to override
just add that variable in front of your command e.g.
 PKG_CONFIG_ALLOW_CROSS=1 cargo build --target=aarch64-unknown-linux-gnu
