Clusterboard
Revision as of 02:15, 8 April 2021 by Dsimic (talk | contribs) (→‎Specifications: Wording improvement)
Please fill in more information if you have it. :)
The SOPine Clusterboard is a way to setup a compact cluster for low power usage and testing. It can hold up to 7 SOPine modules.
Although there is a PINE_A64-LTS/SOPine page already, this page will describe both the Clusterboard and the SOPine modules.
There is a user guide on the forum but sadly the images have disappeared.
While the Cluster board is an hardware open source project, please note that it does not mean this project is "OSH" compliant.
Specifications
These are the SOPine Clusterboard specifications, based on the product introduction:
  • Standard mITX form-factor (167 mm x 170 mm)
  • Built-in eight-port Gigabit Ethernet switch, using RTL8370N ASIC; the switch is unmanaged although the ASIC provides management functions, see this forum thread for further information
  • Seven internal Gigabit Ethernet ports, one for each SOPine module, using connected to the switch using RTL8211E PHYs
  • eMMC module slot, for the first SOPine module
  • Seven USB 2.0 ports, one for each SOPine module
  • GPIO pins exposed for each SOPine module, including the UARTs
  • Gigabit Ethernet port activity LEDs, one for each SOPine module
  • Battery holder for two standard AA 1.5 V batteries, for the real time clock (RTC) on all SOPine modules
  • Barrel-type jack as a power input, 6.3 mm outer diameter and 3.0 mm inner diameter, for a 5 V / 15 A DC power supply
  • Standard 24-pin ATX header as a power input, for an ATX power supply capable of providing at least 15 A at its 5 V output
Please note than only one power input may be used at once. The barrel port is additionally protected by a built-in 15 A fuse.
Layout
Clusterboard 2.3 Front annotated - image by abcde
Clusterboard 2.3 Back - image by abcde
Label Description
A 6.3mm OD/3.0mm ID barrel type DC Jack for +5V 15A 75W power supply
B Gigabit Ethernet Port
C Reset Button
D 2x 1.5V “AA” size Battery Holder for Real Time Clock Port (RTC)
E eMMC connector (only for 1st module)
F SOPine Module slot
G USB2.0 USB-A plug
H MicroUSB-B USB2.0 plug
I Activity LED
J 20-pin expansion connector
K Lithium Battery 3-pin JST connector
L RTL8211E Ethernet Port, with 2 status LEDs
M Unmanaged Gigabit Ethernet Switch - RTL8370N
N ATX Power Connector
O ATX PS_ON 2-pin JST connector
P HDD 5V Power (optional)
Q Resistor (optional, for use with the alternative powering options)
Parts F to L are duplicated for all 7 modules
20 Pin Connector
In the forum there is an image with the (likely) pinout.
SOPine Module
SOPine Front and Back annotated. Picture by abcde.
Label Description
A A64 SoC
B 2GB DDR3 RAM
C AXP803
D SO-Dimm connector
E mSD Card Slot
F (not annotated yet) Power LED
Accessories
  • To operate this board you will need a power supply, Pine advises a "5V 15A power supply with 6.3mm OD/3.0mm ID barrel type DC Jack" which is also available in the store (EU/US versions). There are other ways to power this board, but they are not described here yet.
  • The board works best when it is protected by a (mITX)case, and has some airflow provided by a fan.
  • Each SOPine module can use cooling, both by a casefan, and by using heatsinks on the individual modules. At least the A64 could use some cooling.
  • The first slot can use a eMMC module, which are in the store in 16GB/32GB/64GB/128GB sizes. The modules can be used as a USB stick using a USB adapter. (The eMMC is also readable with the Hardkernel eMMC to microSD converter.)
  • 2x AA batteries, to allow the SOPine nodes to retain the RTC (Real Time Clock) time and date information when the power is disconnected.
Installation
To install this cluster it is important to know which module has which IP address, so you can make sure you connect to the right board, esp with the module that has access to the eMMC.
You can plug in each module individually, and give them a separate name. After that is taken care of you will know which module is used for what. It would also be possible to manually edit each images hosts/hostname files before first boot.
The board has no hotplug functionality, so make sure you only plug/unplug the modules while the power is disconnected from the clusterboard.
As a unmanaged switch is used there is no VLAN support.
Serial console
To boot use the serial console connect the pins to UART0 on the GPIO header and connect using baud 115200
  • Pin 6: GND
  • Pin 7: RTX
  • Pin 8: TXD
The pinouts are available in the forum.
Do not connect the GND connector until the power is on as it can provide power and prevent the board from booting
Operating systems
Armbian
To get the cluster running, start off with a basic Armbian SOPine install on the first module or directly on all the modules. Armbian offers Debian and Ubuntu as options for download.
There is an issue recognizing the network that needs you to make a change to the base image described here, and a PXE issue. If you have a good description, please add it here. The network issue has been resolved in Armbian builds post December 2020 - as described here.
As of February 2021 the current armbian image is not working (see the post on the arbian forum). The latest working version is 21.02.1. To update the system, the package 'linux-dtb-current-sunxi64' needs to be held back by running
echo "linux-dtb-current-sunxi64 hold" | sudo dpkg --set-selections
There are a number of possible basic installation methods.
  • Full install on each module's mSD card.
  • eMMC install on the first module.
  • PXE boot for all modules, from the first module, or an external host.
Others
The current version of netbsd may have the networking issue solved in armbian above.
Frequently asked questions
Q: Are the individual MAC addresses linked to the NIC, or the module.
A: The MAC address is specific to the SOPine module - swapping modules within the Clusterboard does not change the address of the module
Schematics and other
Hardware revisions
The current version is 2.3. There was at least a 2.2 version, if there is more info, please add it here.
Links
