Android SDK for RK3566
Two Android SDKs are available from Pine64 for RK3566 devices:-
QUARTZ64_SDK_android11
Android 11 SDK
for Quartz64 model A SBC and SOQuartz
QUARTZ64-model-A_eink.android11_SDK
Android 11 eink SDK
for PineNote and Quart64 model A SBC
Compiling
Build machine
  • 64 bit Linux (Manjaro tested)
  • At least 16G RAM
  • At least 250G free storage, preferably SSD based
  • Use a POSIX compliant shell such as bash, not zsh (in Manjaro "chsh -s /bin/bash username")
Manjaro packages
The following packages are needed:-
  • make
  • gcc
  • python-pip
  • dtc
  • bison
  • flex
  • cpio
  • unzip
  • zip
Once this is done run
  • pip install pyelftools
You will also need libncurses.so.5. The easiest way to install this appears to be using an Arch AUR package.
  • Enable AUR
  • pamac install ncurses5-compat-libs
Patches
For QUARTZ64-model-A_eink.android11_SDK the following files will need to be updated:-
  • rk3566_ebook/u-boot/arch/arm/mach-rockchip/decode_bl31.py
  • rk3566_ebook/u-boot/arch/arm/dts/Makefile
  • rk3566_ebook/u-boot/scripts/dtc/dtc-lexer.l
  • rk3566_ebook/u-boot/scripts/dtc/dtc-lexer.lex.c
  • rk3566_ebook/u-boot/scripts/dtc/dtc-lexer.lex.c_shipped
  • Download link QUARTZ64-model-A_eink.android11_SDK.patches.04112021.tar
  • Only the PineNote target has been tested at this time.
Compilation process
  • cd rk3566 (for non eink)
  • cd rk3566_ebook (for eink)
  • source build/envsetup.sh
  • lunch
  • ./build.sh -UCKAu
