1080P Pinebook Software Release
Revision as of 04:36, 27 September 2019 by Tllim (talk | contribs)
Contents
Linux Image Releases
Special thanks to Sunxi community, ayufan, and longsleep for their contributions
Manjaro ARM
  • To learn more about Manjaro please visit Manjaro Forum
    • username: manjaro
    • password: manjaro
Manjaro KDE ARM Community Build Image [microSD to eMMC Boot] [19.04]
  • This is microSD boot and install to eMMC version. Please follow bootup screen to complete eMMC installation process
  • Please using this method to refrssh the Pinebook eMMC flash to Manjaro KDE build
    • size: 1.85GB
    • MD5 (GZip file): 0979DA069E1DF46B8A98B77A05CE21DC
Manjaro I3 ARM Community Build Image [microSD / eMMC Boot] [19.04]
Manjaro KDE ARM Community Build Image [microSD / eMMC Boot] [19.06]
Manjaro LXQT ARM Community Build Image [microSD / eMMC Boot] [19.06]
KDE Neon Image
KDE Neon Community Build Image [microSD and eMMC Boot]
Factory Restore KDE Neon Community Build Image [microSD to eMMC] [20181028]
      • MD5 (GZip file): D3C65FB812E125445C2EEA37FA99965F
      • File Size: 1.66GB
    • Default Login (changed after 1st installtion setup) with
      • username: live
      • password: live
Armbian
Armbian Xenial [microSD / eMMC Boot] [5.67]
  • Armbian provides a build system and images for Debian/Xenial with BSP kernel and mainline kernel (beta)
  • Login with
    • username: root
    • password: 1234
  • To find out more about Armbian and available options please visit their site.
Arch Linux mainline XFCE
* From SSH Login default disable root to access . So please first login alarm after command su password root to switch root
AOSC
AOSC Community Build Image with Mate Desktop [microSD Boot] [20181016]
  • To learn more about AOSC, please visit the official AOSC website
  • Known issue: no audio sound output.
  • Login with
    • username: aosc
    • password: anthon
AOSC Community Build Image with Mate Desktop [eMMC Boot] [20181016]
  • DD image to eMMC module using USB adapter for eMMC module.
  • Login with
    • username: aosc
    • password: anthon
DietPi
DietPi Community Build Image [microSD boot]
Forum thread concerning this release can be found here
  • DD image to microSD card module and boot. Highly recommend using Etcher
  • Login with
    • username: root
    • password: dietpi
NetBSD
NetBSD Community Build Image [microSD Boot]
OpenBSD
OpenBSD 6.6-beta, Community Build Image (WindowMaker WM)
Q4OS
Q4OS Community Build Image [microSD Boot]
Android 6.0
Android 6.0.1 Stock Image [microSD to eMMC] [20181001]
  • Rootable build
  • LCD resolution is 1920 x1080
  • Rooted DD image (advise 4GB microSD card and above):
Android 6.0.1 Stock Image [microSD boot] [20181001]
  • Rootable build
  • Please use high performance microSD card for Android boot which request frequent random read access.
  • Please ignore warning message regarding SD corrupted on home screen upper left corner
  • DD images:
Linux BSP SDK
Linux BSP [4.0]
Linux BSP [3.0]
Android SDK
Android Oreo [v8.1]
Android Nougat [v7.0]
Android Marshmallow [v6.0]
Mali-400 64-bit Driver
Mali-400 64-bit Driver [20160622]
Other Tools
Checking microSD Card Performance and whether it is Counterfeit
This will help you to determine if the SD-Card is Counterfeit Drive or not
