1080P Pinebook Software Release
Revision as of 21:29, 24 April 2019 by Luke (Talk | contribs) (Manjaro ARM)
Jump to: navigation, search
Linux Image Releases
Special thanks to Sunxi community, ayufan, and longsleep for their contributions
KDE Neon Image
KDE Neon Community Build Image [microSD and eMMC Boot]
Factory Restore KDE Neon Community Build Image [microSD to eMMC] [20181028]
Arch Linux mainline XFCE
* From SSH Login default disable root to access . So please first login alarm after command su password root to switch root
AOSC
AOSC Community Build Image with Mate Desktop [microSD Boot] [20181016]
  • To learn more about AOSC, please visit the official AOSC website
  • Known issue: no audio sound output.
  • Login with
    • username: aosc
    • password: anthon
AOSC Community Build Image with Mate Desktop [eMMC Boot] [20181016]
  • DD image to eMMC module using USB adapter for eMMC module.
  • Login with
    • username: aosc
    • password: anthon
DietPi
DietPi Community Build Image [microSD boot]
Forum thread concerning this release can be found here
  • DD image to microSD card module and boot. Highly recommend using Etcher
  • Login with
    • username: root
    • password: dietpi
Manjaro ARM
Manjaro KDE ARM Community Build Image [microSD / eMMC Boot] [19.02]
  • To learn more about Manjaro please visit Manjaro Forum
    • username: <set on inital boot>
    • password: <set on inital boot>
Manjaro LXQT ARM Community Build Image [microSD / eMMC Boot] [19.02]
NetBSD
NetBSD Community Build Image [microSD Boot]
Q4OS
Q4OS Community Build Image [microSD Boot]
Android 6.0
Android 6.0.1 Stock Image [microSD to eMMC] [20181001]
  • Rootable build
  • LCD resolution is 1920 x1080
  • Rooted DD image (advise 4GB microSD card and above):
Android 6.0.1 Stock Image [microSD boot] [20181001]
  • Rootable build
  • Please use high performance microSD card for Android boot which request frequent random read access.
  • Please ignore warning message regarding SD corrupted on home screen upper left corner
  • DD images:
Linux BSP SDK
Linux BSP [4.0]
Linux BSP [3.0]
Android SDK
Android Oreo [v8.1]
Android Nougat [v7.0]
Android Marshmallow [v6.0]
Mali-400 64-bit Driver
Mali-400 64-bit Driver [20160622]
Other Tools
Checking microSD Card Performance and whether it is Counterfeit
This will help you to determine if the SD-Card is Counterfeit Drive or not
