1080P Pinebook
Revision as of 03:54, 18 May 2019 by Samueldr (Talk | contribs) (There is no SPI NOR Flash on the Pinebook)
Jump to: navigation, search
1080P Pinebook
Under '1080P Pinebook Software and OS Image Download Section' you will find a complete list of currently supported Operating System images that work with the Pinebook as well as other related software. The list includes OS images and descriptions of:
Under 'Service Guides for Pinebook' you can see instruction guides concerning disassembly of:
  • 11.6″ Pinebook Lithium Battery Pack Removal Guide
  • 11.6″ Pinebook LCD Panel Screen Removal Guide
  • 11.6″ Pinebook eMMC Module Removal Guide
Pinebook Information
  • Dimensions: 299mm x 200mm x 12mm (WxDxH - 11" Pinebook)
  • Weight: 1.04Kg (11" Pinebook)
  • Input Power: DC 5V @ 3A
SoC and Memory Specification
  • Based on Allwinner A64
  • Quad-core ARM Cortex-A53 [email protected]
  • VFPv4 Floating Point Unit
  • 512KB L2 cache
GPU Architecture
  • System RAM Memory: 2GB
Battery
  • Lithium Polymer Battery (10,000mAH)
Video
  • Mini Digital Video Port (Type A - mini)
Audio
  • Loudspeaker
Network
  • WiFi 802.11 b/g/n with Bluetooth 4.0
  • 10/100Mbps USB Ethernet Dongle (Optional)
Storage
  • eMMC port: 16GB eMMC module, can be upgraded to 32GB or 64GB eMMC module
  • USB - 2 x USB 2.0 Host port
Expansion Ports
  • mini Digital Video port
  • microSD card port - support SD, SDHC, SDXC uo to 256GB
  • 2x USB 2.0 port
  • earphone plug with UART console mux circuit
Pinebook Schematics and Certifications
Other Resources
FAQ / Tips and tricks
Key left of Z ( \ | )
How to map the key next to Z to the symbols on \ and | (rather than <>) ?
Choose the alternative international US keyboard layout and variant. The name will depend on you desktop environment:
  • English (US, alt. intl.)
  • English (US, international AltGr Unicode combining, alternative)
  • English (US, alternative international)
Note: keyboard variants with similar names as the ones above change the upper left key for ` and ~. You have to press that key twice to get the desired char. This happens with the alt-intl variant. Choose the altgr-intl variant (or however it is called in your desktop environment) and it should work as expected.
To set the keyboard layout and variant in the terminal for X-Windows use:
setxkbmap -layout us -variant altgr-intl
The Archlinux Wiki has some good help if you need to tweak your layout further [2]
Key between Fn and Alt (Menu)
How to map the key between Fn and Alt to SUPER / META ?
The initial setup in many desktop environments maps the key between Fn and Alt to MENU. Although the menu key can be useful as well (e.g. spell correction in the browser) many desktop environments and window manager use the Super key for many other useful functions. And users are probably more used to have the META key near Ctrl and Alt.
In X-windows the following command maps the key between Fn and Alt to META and the Caps-Lock key to MENU.
setxkbmap -option caps:menu,altwin:alt_super_win
Set display brightness in the terminal
To set the display brightness in the terminal use xbacklight (if available in your distro):
xbacklight -setXX
XX is the percentage (%) of brightness. E.g. for 70% brightness
xbacklight -set70
If you use LXQt you can also use:
pkexec lxqt-backlight_backend --inc
pkexec lxqt-backlight_backend --dec
For an alternative solution please see the scripts discussed in this thread: [3]
Get battery % in CLI
As ACPI is not compatible with ARM, to gather the % battery this can be used:
cat /sys/class/power_supply/battery/capacity
Firefox font size
How to get a useful font size with firefox ?
To have every web page displayed in a larger more readable font size type about:config in the search bar and confirm on the first page that you want to make changes. Then search for this parameter:
layout.css.devPixelsPerPx
and modify the value (right click) to something between 1.2 to 1.5 depending on your preferences.
In addition to that you can set in Preferences -> General -> Fonts & Color -> Advanced Minimum font size to 16
Disable wireless power management
If having issues with wifi connectivity, try to disable power management in the 8723cs module options, adding rtw_power_mgnt=0 in /etc/modprobe.d/8723cs.conf
options 8723cs rtw_initmac=00:ba:ch:16:85:46 rtw_power_mgnt=0
Touchpad acceleration and scroll direction.
To set touchpad parameters from the cli you can use the command xinput. To use it correctly you first need to determine the device id / name for your touchpad. Use
xinput list
to do so. You are looking for a line like this:
HAILUCK CO.,LTD USB KEYBOARD Mouse      	id=7	[slave  pointer  (2)]
With the device id = 7 found you can list the parameters that can be set with xinput.
xinput list-props 7
The result looks similar to this:
device 'HAILUCK CO.,LTD USB KEYBOARD Mouse':
libinput Natural Scrolling Enabled (256):	0
libinput Accel Speed (265):	0.000000
To change the parameter use xinput set-prop
To set reverse scrolling for the touchpad use this command
xinput set-prop 7 'libinput Natural Scrolling Enabled' 1
To set mouse speed
xinput set-prop 7 'libinput Accel Speed' 0.95
Check different numbers for 0.95 to meet your needs. For more details on xinput and mouse speed also see the Archlinux Wiki [4]
