SOPINE Software Releases
Note that, SOPINE OS images are also compatible with PINE A64-LTS
Linux Image Releases
Xenial Mate
Xenial Mate [20170306] built by PINE64
  • This is a build including DE based on longsleep works and may not have all the up-to-date features offered by longsleep and Sunxi community. For latest build, you can create one and following this thread
  • This build optimizes Gigabit Ethernet parameter and improves on GbE connectivity
  • Included Mate Desktop, Firebox Browser, and LibreOffice Suite
  • Included libvdpau-sunxi with SMPlayer
  • Included with Wifi and Bluetooth
  • Included library set that provides access to the GPIO headers in Linux as provided by community member KB3VGW (https://devhub.io/repos/kb3vgw-wiringPi-Pine64)
  • Not yet optimize for Graphic acceleration
  • Auto execute resize_rootfs.sh script on first boot-up to resize the root partition in order to fully utilize the SD Card
  • Suitable for SOPINE Board only
  • Login with
    • username: ubuntu
    • password: ubuntu
openSUSE Base Image
openSUSE Base Image [20170328]
  • Thanks to Terra854 for contributing the openSUSE build based on longsleep's kernel
  • You can visit the project's website here
  • To find out more about openSUSE on the PINE64 please visit the PINE64 forum thread
  • Login with
    • Username: pine64
    • Password: pine64linux
    • Root password: pine64root
The image includes a config tool which, among other options, allows users to install a desktop environment: sudo /usr/local/sbin/pine64-config.sh
Armbian
Armbian Community Build Image [microSD Boot]
  • Armbian provides a build system and images for Debian/Xenial with BSP kernel and mainline kernel (beta)
  • Two versions of Armbian images are available: legacy and vanilla. Legacy is strongly recommended for most users, whilst vanilla includes a mainline kernel which doesn't support DVFS, HDMI, onboard analog audio output, onboard IR receiver, CSI, DSI and TP interfaces
  • Login with
    • username: root
    • password: 1234
  • Setup SOPINE Armbian LCD and Camera
Arch Linux mainline XFCE
* From SSH Login default disable root to access . So please first login alarm after command su password root to switch root
OpenMediaVault
OpenMediaVault Community Build Image [microSD Boot]
Volumio Digital Audio Player
Volumio Digital Audio Player [2.383-2018-03-17]
  • This version works with (Spdif / Coaxial / RCA).
  • You need to enable Volume Normalization in the Playback Options to fix sound low.
  • supports booting from eMMC and SD card.
  • supports a select number of simple I2S DACS. tested with the Pine64 DAC POT, a wired ES9023 DAC module and a pcm5121 DAC module.
  • Login with
    • Username: volumio
    • Password: volumio
Volumio Digital Audio Player [2.315-2017-11-11]
  • For listen headphones this version have "hiss"
  • Login with
    • Username: volumio
    • Password: volumio
Android Image Releases
Android 7.x
Android 7.1 Community Build Image [v0.3.10-r66]
  • ayufan Android 7.1 ver 0.3.10 GitHub
  • Please use good random IO access performance microSD card such as Samsung EVO when try out Android 7.1
  • DD images (advise 4GB microSD card and above):
  • Please allows some time (around 5 minutes) for the initialization process on 1st boot
Android 6.x
Android 6.0.1 [20170726]
[OLD] Android 6.0.1 [20170331]
Android 5.x
Android 5.1.1 [20160630]
