SOPINE Armbian LCD and Camera
Revision as of 08:05, 7 December 2017 by Pineadmin (talk | contribs) (Created page with " == LCD == <pre<noinclude></noinclude> style="white-space: pre-wrap; white-space: -moz-pre-wrap; white-space: -pre-wrap; white-space: -o-pre-wrap; word-wrap: break-word;"> 1....")
LCD
1. DD the Armbian SOPINE image to the microSD Card and run on the board
2. Login through the terminal
3. # vi /boot/armbianEnv.txt     (Change off to on)
pine64_lcd=on
4. # vi /etc/modules     (Add following line)
gt9xxf_ts
5.  reboot
Then the display will be on LCD and not HDMI
Camera
3. Install Ubuntu Xenial Mate with ayufan's script
# cd ~
# wget https://github.com/longsleep/build-pine64-image/raw/master/simpleimage/platform-scripts/install_desktop.sh
# chmod +x install_desktop.sh
# ./install_desktop.sh mate
4. # vi /boot/armbianEnv.txt     (Set to "s5k4ec" or "ov5640" depending on your camera module)
camera_type=s5k4ec
5. # vi /etc/modules     (Add the following depending on your camera_type "s5k4ec" or "ov5640" above. Note that "vfe_v4l2" has a small letter 'L'2 not 12)
s5k4ec
vfe_v4l2
6. # reboot
7. Following https://github.com/avafinger/pine64_camera  (Change "s5k4ec" to "ov5640" depending on your camera module)
# apt-get update
# apt-get upgrade
# apt-get remove --purge guvcview
# apt-get remove --purge libguvcview-1.1-1
# modprobe -r -f vfe_v4l2
# modprobe -r -f s5k4ec
# modprobe s5k4ec
# modprobe vfe_v4l2
# ls /dev/video0
# dmesg | grep OK
# sudo apt-get install libmp3lame-dev libx264-dev libpulse-dev libv4l-dev libsdl1.2-dev libgtk-3-dev portaudio19-dev libpng12-dev libavcodec-dev libavutil-dev libudev-dev libusb-1.0-0-dev libpulse-dev libgsl0-dev libv4l-dev
# cd ~
# wget https://raw.githubusercontent.com/avafinger/pine64_camera/master/libguvcview-1.2-1_2.0.3%2Bdebian-1_arm64.deb
# wget https://raw.githubusercontent.com/avafinger/pine64_camera/master/guvcview_2.0.3%2Bdebian-1_arm64.deb
# dpkg -i libguvcview-1.2-1_2.0.3+debian-1_arm64.deb
# dpkg -i guvcview_2.0.3+debian-1_arm64.deb
8. For testing, use Xenial Mate -> Applications -> Sound & Video -> guvcview
OR command line
# guvcview -d /dev/video0 -x 640x480 -r sdl -f yu12
# guvcview -d /dev/video0 -x 640x480 -r sdl -f nv12
