SOEDGE
Revision as of 23:41, 18 October 2020 by Tllim (talk | contribs)
SOEdge_Software_Release
penguin.png Armbian
Under 'Guides for PINE64 model A accessories' you can find instructions and guides concerning:
  • Enclosures
  • Bluetooth and WiFi module
  • Real Time Clock (RTC) battery
  • Real Time Clock (RTC) battery holder
  • First and third party cases
  • Featured 3D printed cases (and more)
SoC and Memory Specification
  • Based on Rockchip RK1808
  • Dual-core ARM Cortex-A35 Processor@1600-2000Mhz
  • A power-efficient ARM 64-Bit Armv8-A architecture
  • AArch32 for full backward compatibility with Armv7
  • VFPv4 Floating Point Unit
  • TrustZone security technology
  • Neon Advanced SIMD
  • DSP and SIMD extensions
  • VFPv4 Floating point
  • 128KB L2 cache
Neural Process Unit NPU Capability
  • NPU IP from Verisilicon Vivantee
  • Support max 1920 Int8 MAC operation per cycle
  • Support max192 Int16 MAC operation per cycle
  • Support max 64 FP16 MAC operation per cycle
  • 512KB internal buffer
  • RAM Memory Variants: 2GB DDR4.
  • Storage Memory: SPI Flash and optional eMMC module from 16GB up to 128GB
SOPine Baseboard Features
Video
  • Digital Video (Type A - full)
Audio
Network
  • 10/100/1000Mbps Etherne
Storage
  • USB - 2 USB2.0 Host port
Expansion Ports
  • 2x20 pins "Pi2" GPIO Header
  • PCIe 2x open ended slot
SOEdge Module and Baseboard Information, Schematics, and Certifications
SOEdge/SOPine Cluster Board Resource
Other Resources
