PINE A64 Software Releases
Note that, PINE A64(+) OS images are not compatible with PINE A64-LTS due to LPDDR3 memory configuration. For PINE A64-LTS, please use the 'SOPINE OS images'
Linux Image Releases
Special thanks to Sunxi community and longsleep for their contributions
Xenial Mate
Xenial Mate [20161215] built by PINE64
  • This is a build including DE based on longsleep works and may not have all the up-to-date features offered by longsleep and Sunxi community. For latest build, you can create one and following this thread.
  • This build optimizes Gigabit Ethernet parameter and improves on GbE connectivity
  • Included Mate Desktop, Firebox Browser, and LibreOffice Suite
  • Included with Wifi and Bluetooth
  • Included library set that provides access to the GPIO headers in Linux as provided by community member KB3VGW (https://devhub.io/repos/kb3vgw-wiringPi-Pine64)
  • Not yet optimize for Graphic and Video HW acceleration
  • Auto execute resize_rootfs.sh script on first boot-up to resize the root partition in order to fully utilize the SD Card
  • Suitable for 1GB/2GB PINE A64+ Board, not advise to run on 512MB PINE A64 Board
  • DD image (for 8GB micoSD card and above):
  • Login with
    • username: ubuntu
    • password: ubuntu
Xenial Base Image
http://wiki.pine64.org/images/5/59/Ubuntu-logo32.png
Xenial Base Image [20161218-1] by longsleep
  • This is the latest Xenial 16.04 image provided by lonsleep. NB. This is a base image and doesn't come with a DE
  • longsleep's support thread on PINE64 Forum
  • Suitable for 512MB/1GB/2GB PINE A64(+) variants
  • Login with
    • username: ubuntu
    • password: ubuntu
  • Execute sudo /usr/local/sbin/resize_rootfs.sh script to resize the root partition in order to fully utilize the SD Card
  • To update to the newest uboot, kernel and fixes use scripts found in /usr/local/sbin/
  • Install Mate DE using: sudo /usr/local/sbin/install_mate_desktop.sh
Xenial Minimal Image
Xenial Minimal Image [0.6.2-77] by ayufan
  • This is the latest Xenial 16.04 image provided by ayufan based on longsleep base image. NB. This is a base image and doesn't come with a DE
  • ayufan's GitHub
  • Suitable for 1GB/2GB PINE A64(+) variants
  • Login with
    • username: pine64
    • password: pine64
  • Install Mate DE using: sudo /usr/local/sbin/install_desktop.sh
openSUSE Base Image
openSUSE Base Image [20170328]
The image includes a config tool which, among other options, allows users to install a desktop environment: sudo /usr/local/sbin/pine64-config.sh
Armbian
Armbian Community Build Image [microSD Boot]
  • Armbian provides a build system and images for Debian/Xenial with BSP kernel and mainline kernel (beta)
  • Two versions of Armbian images are available: legacy and vanilla. Legacy is strongly recommended for most users, whilst vanilla includes a mainline kernel which doesn't support DVFS, HDMI, onboard analog audio output, onboard IR receiver, CSI, DSI and TP interfaces
  • Suitable for 512MB/1GB/2GB PINE A64(+) Boards
  • Login with
    • username: root
    • password: 1234
Debian Jessie Mate
Debian Jessie with Mate DE [3.10.102 BSP 2] by Lenny Raposo
Arch Linux mainline XFCE
* From SSH Login default disable root to access . So please first login alarm after command su password root to switch root
Fedora Base Image
Fedora 24 Base Image [091016] (ALPHA) End Of Life
  • Thanks to Terra854 for contributing the Fedora build based on longsleep's kernel
  • You can visit the project's website here
  • To find out more about the development and progress please see the PINE64 forum thread
  • Login with
    • Username: pine64
    • Password: pine64linux
Do note that this is an ALPHA build - please don't install a desktop environment
Gentoo
Gentoo [20160804]
  • A Gentoo image built by Xalius
  • To learn more about the Gentoo linux build please see the forum thread
  • Login with
    • Username: gentoo
    • Password: gentoo
    • Root Password: gentoo
Q4OS
Q4OS [24-r1]
[OLD] Q4OS [1806]
OpenWRT
OpenWRT Community Build Image [microSD Boot]
DietPi
DietPi [v145]
  • DietPi is a lightweight linux distribution of Debian Jessie
  • To find out more about DietPi on the PINE64 and available tweaks to the installation please visit the PINE64 forum thread
  • Login with
    • username: root
    • password: dietpi
openHAB 2
openHAB 2 [v1.4]
[OLD] openHAB 2 [v1.3]
  • This image is based on the official Xenial Base Image by longsleep and the openHABian project
  • DD images (for 4GB microSD card and above)
  • Login with
    • username: openhabian
    • password: openhabian
  • Initial boot can take more than 15 minutes for openHABian to initialized. Once initialized, the display will be off. Then reboot the PINE A64(+)
  • Go to http://openhabianpine64:8080 or http://{pine64_ip}:8080/ on your PC web browser. ({pine64_ip} can be obtained by Login to PINE A64(+) and execute "ifconfig")
  • For getting started with openHAB, please refer to http://docs.openhab.org/
China NeoKylin “中标麒麟”
China NeoKylin “中标麒麟” [20170210]
Volumio Digital Audio Player
Volumio Digital Audio Player [2.315-2017-11-11]
  • This version works with (Spdif / Coaxial / RCA).
  • You need to enable Volume Normalization in the Playback Options to fix sound low.
  • For listen headphones this version have "hiss"
  • Login with
    • Username: volumio
    • Password: volumio
Volumio Digital Audio Player [2.312-2017-11-05]
  • For listen headphones you need to disable Volume Normalization to fix "hiss"
  • Login with
    • Username: volumio
    • Password: volumio
Volumio Digital Audio Player [2.166-2017-05-11]
  • Login with
    • Username: volumio
    • Password: volumio
FalconGate
FalconGate [20170705]
  • FalconGate is an open source smart gateway which can protect your home devices against hackers, Malware like Ransomeware and other threats
  • Visit the FalconGate GitHub and its GitHub Wiki for more information
  • Login with
    • Username: admin
    • Password: falcongate
    • Root Password: falcongate
  • Normally there will be around 5 minutes of boot time when you disable DHCP on your router as suggested by FalconGate
  • You may also change the default IP Address (192.168.0.2) and Gateway (192.168.0.1) in /etc/network/interfaces to match your Router subnet
  • Go to the https://[PINE A64(+) FalconGate IP Address] on your web browser to access to the FalconGate admin web interface
motionEyeOS
motionEyeOS [20171003]
  • motionEyeOS is a Linux distribution that turns a single-board computer into a video surveillance system. The OS is based on BuildRoot and uses motion as a backend and motionEye for the frontend
  • Visit the motionEyeOS GitHub and its GitHub Wiki for more information
  • Login with
    • Username: admin
    • Password:
    • Scan for its IP with hostname MEYE-* and go to the admin web interface http://[PINE A64(+) motionEyeOS IP Address] and after login, you should able to see the output of the CAMERA MODULE on the web interface
    • Use the PINE64 USB SERIAL CONSOLE/PROGRAMMER and login
OpenMediaVault
OpenMediaVault Community Build Image [microSD Boot]
Android Image Releases
Android 7.x
Android 7.1 Community Image [v0.3.10-r66]
[OLD] Android 7.0 Community Beta Image [v1.11.0-r67]
Android 6.x
Android 6.0 (HDMI Video Output) [20170112 v2.0.1]
Android 6.0.1 (LCD Panel Video Output) [20170209]
Android 6.0 Community Beta Image [v1.0.0-r19]
Android 5.x
Android 5.1.1 (HDMI Video Output) [20161208 v1.2.8]
[OLD] Android 5.1.1 (HDMI Video Output) [20160711 v1.2.6]
[OLD] Android 5.1.1 (LCD Panel Video Output) [20160603]
Bliss OS
Bliss OS [20170919]
  • An Open-Source OS, based on Android, for phones, tablets & PCs
  • Multi-Windows Android Build
  • You can visit the Bliss OS website here
  • This version best suitable for 2GB PINE A64+ Board, can runs on 1GB PINE A64+ Board with performance lagging, not suitable for 512MB PINE A64 Board
  • DD images:
  • Use the Taskbar launcher for Desktop mode UI
Remix OS
[DISCONTINUED]
Remix OS 2.0 [20170105]
NetBSD
http://www.invisible.ca/arm/
  • PINE64/PINE64+ images are available with daily builds on the link above.
  • Default connection is over HDMI cable and USB keyboard.
  • Default username is "root" without password. Ssh remote login is not enabled by default.
Windows 10 IoT Releases
Win10 IoT [10.0.15063.0_20170602]
  • 10.0.15063.0_20170602
    • Update Notes since 10.0.15063.0_20170524:
      • Fix the failure of default application installation caused by a app certification issue
      • Fix that the default application cannot start automatically after installation
      • Fix Ethernet initialization problem and now the Ethernet will start successfully every time
      • Enable the usermode access for all unusable GPIO pins in Pi-2 bus( later provide a UWP sample to show how to control these pins )
    • Extra Notes:
  • 10.0.15063.0_20170524
    • Some Updates:
      • Update the OS version to build v.10.0.15063.0 (Creators Update)
      • New page style of Device Portal, visit https://deviceipaddr:8080 to check it
      • Built-in Cortana assistant, need to be enabled in settings page in default app and Device Portal
      • Support on-screen keyboard, need to be enabled in Device Portal
      • Enable 100M Ethernet and fix some bugs
      • Support built-in UART bus in A64 SoC(not built in the ffu, later provide driver binary and deployment helper)
      • Support built-in IR module in A64 SoC(not built in the ffu, later provide source code and dev doc for developers in community)
    • Known Issues:
      • Kernel debug is enabled by default. This will slow the bring-up process. If a kernel debug is not necessary for you, visit Device Portal and navigate to Processes->Run Command page, run this command to disable:
        • Bcdedit /store C:\EFIESP\EFI\Microsoft\boot\BCD /set {default} debug off
      • An PnP bug in audio device may cause a blue screen when acting software shutdown
      • Ethernet device may not start with problem code 12 at the first time to bring up
[OLD] Win10 IoT [20161121 Beta]
Linux BSP SDK
Linux BSP [3.0]
Android SDK
Android Nougat [v7.0]
Android Marshmallow [v6.0]
Android Lollipop [v5.1.1]
Mali-400 64-bit Driver
Other Tools
Checking microSD Card Performance and whether it is Counterfeit
This will help you to determine if the SD-Card is Counterfeit Drive or not
