PineCube
Revision as of 04:50, 14 October 2020 by Tllim (talk | contribs)
PAGE UNDER CONSTRUCTION, INFO SUBJECT TO CHANGE
Specifications
  • Dimensions: 55mm x 51mm x 51.5mm
  • Weight: 55g
  • Storage:
    • MicroSD slot, bootable
    • 128Mb SPI Nor Flash, bootable
  • Cameras: OV5640, 5Mpx
  • CPU: Allwinner(Sochip) ARM Cortex-A7 MPCore, 800MHz
  • RAM: 128MB DDR3
  • I/O: 10/100Mbps Ethernet with passive PoE, USB 2.0 A host, 26 pins GPIO port, internal mic
  • Network
    • WiFi
  • Screen: optional 4.5" RGB LCD screen
  • Battery: optional 950-1600mAh model: 903048 Lithium Polymer Ion Battery Pack, can be purchase at https://www.amazon.com/AKZYTUE-1200mAh-Battery-Rechargeable-Connector/dp/B07TWHHCNK/ Amazom.com]
  • Misc. features:
    • Volume and home buttons
    • Speakers and Microphone
    • DC in: 5V 1A from microUSB Port and GPIO port, 8V-24V from Ethernet passive PoE.
PineCube board information, schematics and certifications
  • LCD touch screen panel information:
  • Lithium battery information:
Operating Systems
Stock Linux
SDK
Stock Linux
How to compile
Recommended system requirements:
  • OS: (L)Ubuntu 16.04
  • CPU: 64-bit based
  • Memory: 8 GB or higher
  • Disk: 15 GB free hard disk space
Install required packages
sudo apt-get install p7zip-full git make u-boot-tools libxml2-utils bison build-essential gcc-arm-linux-gnueabi g++-arm-linux-gnueabi zlib1g-dev gcc-multilib g++-multilib libc6-dev-i386 lib32z1-dev
Install older Make 3.82 and Java JDK 6
pushd /tmp
wget https://ftp.gnu.org/gnu/make/make-3.82.tar.gz
tar xfv make-3.82.tar.gz
cd make-3.82
./configure
make
sudo apt purge -y make
sudo ./make install
cd ..
# Please, download jdk-6u45-linux-x64.bin from https://www.oracle.com/java/technologies/javase-java-archive-javase6-downloads.html (requires free login)
chmod +x jdk-6u45-linux-x64.bin
./jdk-6u45-linux-x64.bin
sudo mkdir /opt/java/
sudo mv jdk1.6.0_45/ /opt/java/
sudo update-alternatives --install /usr/bin/javac javac /opt/java/jdk1.6.0_45/bin/javac 1
sudo update-alternatives --install /usr/bin/java java /opt/java/jdk1.6.0_45/bin/java 1
sudo update-alternatives --install /usr/bin/javaws javaws /opt/java/jdk1.6.0_45/bin/javaws 1
sudo update-alternatives --config javac
sudo update-alternatives --config javaws
popd
Unpack SDK and then compile and pack the image
7z x 'PineCube Stock BSP-SDK ver1.0.7z'
mv 'PineCube Stock BSP-SDK ver1.0' pinecube-sdk
cd pinecube-sdk/camdroid
source build/envsetup.sh
lunch
mklichee
make -j3
pack
