PineCube
Revision as of 20:51, 24 August 2020 by Tllim (talk | contribs) (Created page with "PAGE UNDER CONSTRUCTION, INFO SUBJECT TO CHANGE == Specifications == * '''Dimensions:''' 55mm x 51mm x 51.5mm * '''Weight:''' 55g * '''Storage:''' ** MicroSD slot, bootable...")
Specifications
  • Dimensions: 55mm x 51mm x 51.5mm
  • Weight: 55g
  • Storage:
    • MicroSD slot, bootable
    • 128Mb SPI Nor Flash, bootable
  • Cameras: OV5640, 5Mpx
  • CPU: Allwinner(Sochip) ARM Cortex-A7 MPCore, 800MHz
  • RAM: 128MB DDR3
  • I/O: 10/100Mbps Ethernet with passive PoE, USB 2.0 A host, 26 pins GPIO port, internal mic
  • Network
    • WiFi
  • Screen: optional 4.5" RGB LCD screen
  • Battery: optional 1200MAh (1.2Ah)
  • Misc. features:
    • Volume and home buttons
    • Speakers and Microphone
    • DC in: 5V 1A from microUSB Port and GPIO port, 8V-24V from Ethernet passive PoE.
PineCube board information, schematics and certifications
  • LCD touch screen panel information:
  • Lithium battery information:
Operating Systems
Stock Linux
SDK
Stock Linux
